Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I am trying install RTH2301b but the old thermostate i ave has only two wire white and black were should i connect them on the new one
  • 455 Answers
Hello You have a HEAT only thremostat.BLACK=RH or R termnial , WHITE goes to W.
Posted on Sep 04, 2010
240 volt thermostata
Aube Technologies should be able to supply wiring information.
Jan 28, 2014 | Aube Technologies TH115-A-240S - Aube...
Im in a apartment just moved In and the honeywell thermostate im replacing with a hunter brand, non-programmable thermostate, there was only 3 wires hooked up, out of the electrical wiring theres a red...
Need to know if you have central air as well. If you don't, then hook up the Red to R, White to W. you @ least have heat. any other wires you hook up will be dependent on what type of system you have ie boiler, forced air, etc.
Oct 26, 2013 | Heating & Cooling
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
I'm trying to install this for our outdoor Christmas lights. The wall switch box has 1 black, 1 white, and 1 bare (ground). Where do I connect the red "timer" wire from the timer unit? When I...
Single pole application, red wire is capped off.
http://waterheatertimer.org/ST01C-program.html#ST01C
That being said, you still have to connect Blue and Black wires correctly.
Switch has two wires, if you do not know which wire is which, follow instructions below.
Connect Blue and Black to either wire.
Turn on power.
Push ON-OFF button.
If lights work, then timer is wired correctly.
If lights don't work, then reverse Blue and Black.
Be sure outdoor bulb is working.
I have a long story about that, and tested every wire and breaker ... and bulb was burned out.
Nov 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I am changing an old thermostat, and converting it in to a honeywell RTH2310B. The original thermostate has 3 wires, in red,black, and white. The new one has white, yellow, and green. How do I proceed?
Hi, the new stat should have rh, and rc, with a jumper wire on it. leave it on, and connect your red to either one. Connect white to W, and the black the must be using for fan, so connect it to G, if it was being used on the other stat. If it wasn't, tape it off. You should be up and running. I take it this is a heat only application.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Nov 03, 2010 | Honeywell Programmable Thermostat Heater
Electrical hookup
If you have the hot and common wires connected (black to black and white to white) it should work. If not, try connecting a length of wire to the ground wire and connect to ground, such as a copper cold water pipe, radiator, heater vent, or the ground terminal in a nearby outlet. If it works then, you need to splice an extension to the ground wire to connect in the box where the hot and common are. Keep in mind all splices must be inside an approved box. If it still doesn't work, yours is not the first nor the last defective hood to be sold.
Feb 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
200 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
