Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
My sub zero 650 freezer section making loud fan type noise this morning. It was 38 degrees, (maybe freezer drawer was left open last night?) now down to 24 degrees, still making noise. Could it be my evaporator fan motor going? Just had the fridge repaired for the common pipe leaks. Condensor clean fan works on fridge Temperture good.
22yooper
  • 828 Answers
SOURCE: sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Posted on Jun 03, 2008
  • 125 Answers
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Posted on Jul 19, 2008
  • 1462 Answers
SOURCE: Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Posted on Nov 04, 2008
SOURCE: Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Posted on Nov 12, 2008
  • 56 Answers
SOURCE: Sub-zero Fridge not cooling and ice forming
You do have a leak and it will be in the evaporator. So call a factory authorized company and have it replaced.The warranty of a Sub Zero sealed system is full parts and labor for years 1-5 and parts only in year 6-12. Sub Zero expects a lot of their service companies so it behooves you to call one. To find an authorized company go to http://www.subzero.com/locator/locator.aspx?type=0&zip= or call 800-222-7820
Posted on Jan 08, 2009
Audible motor boat kind of sound when drawer is shot...stops when freezer draw is opened
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
May 07, 2011 | Sub-Zero 650 / O Bottom Freezer...
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the...
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Apr 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 has melted and refrozen cubes under normal cubes - I have emptied the ice cube tray three times, made sure it is dry before putting it back, and each time there is eventual frozen water...
maybe the water valve keep open. try replace the water valve. the ice maker energized the water valve. and release water. MAYBE in each cycle after energized the valve this one keeps open. ttry replace is really simple..... good luck...... leave a comment if it this good for you
Jan 12, 2010 | Sub-Zero 650 / O Bottom Freezer...
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer stuck on -20 degrees
well it depends on how long the door was open for during the cleaning, your evap coil was unable to cool the unit due to the warm air coming in, that will cause the evap coil to over frez . un-plugging the unit may work but the best thing to do is force it into a defrost you can do that by pressing and holding the ice key on the key pad for 10 sec or till you hear the freezer shut down this will thaw the ice on the coil and the unit with come back on within 20 to 30 Min's
Jan 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
162 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
