Question about Craftsman 4 Cycle Blower/Vac
What is the gap for the plug for a craftsman leaf blower model 358794741?
5 Suggested Answers
SOURCE: can't start my leaf blower
You might have damaged the "spring re-wind" or the cord is jambed. If you know how to disassemble the housing (see owner's manual), then check to see if the cord is stuck, then manually re-wind it and pull it slowly and then let it rewind slowly. Do not attempt to remove the spring housing unless you have several hours to spare to rewind the spring, as it will "unspring" with great force - all over the place. Zing! The only other solution, of course, is to take it back to Sears for repair. Yuck. Have had several in the shop for other reasons that couldn't be easily DIY repaired - time after time.
Most ****-smen products cause more headaches than they prompt smiles of joy. I have pretty much determined that the manufacturers of ****-smen (who ever they are) plan it that way. Most home-owner products of this sort only last for 3-4 years, if you're lucky. I have also tried other brands; none are much to rave about. You could always do what I do, if I don't have any warrantee time left, or an extended agreement; give it a nice funeral (or run over it with a tank and send the remains to the CEO of Sears) and spend the money for a new one (any brand - even Craps-men) or use a rake..... :(
If you do get it to work, try pulling the cord with less force and NEVER let it "spring back" by letting go of the handle. Let is rewind as you hold it. GOOD LUCK!
Posted on Nov 09, 2008
  • 22 Answers
SOURCE: replace the ignition module on a craftsman blower
we alway use a matchbook cover
Posted on Nov 27, 2008
kachbibi1
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
  • 10 Answers
SOURCE: Craftsman 200 mph model 358.794741 Leaf
You need to check if the piston was fired, or if the piston rings was stick.
Posted on Jan 11, 2011
What is spark plug gap for leaf blower
Spark gap should be approx. 0.025. Hope this helps.
May 31, 2014 | Craftsman Garden
Igition coil gap for craftsman model 536886621
ALL ignition coils are gapped at about .010 or ten thousand. Rule of thumb, normal business card inbetween flywheel and coil
Dec 21, 2013 | Craftsman 536.886520 Snow Blower
I need the spark plug gap for a Craftsman Leaf Blower M/N: 358.794741 please.
First, I would like to give you a copy of your online owner's manual:
http://www.managemylife.com/mmh/owner_manuals/15531/CRAFTSMAN-Blower-Gas-L0803240?brand_name_search=+358.794741+
The gap is NOT mentioned in the maintenance section. The normal setting for a machine of this type is a gap of .030"
May 21, 2011 | Craftsman Garden
I am gettinno spark from the spark plug I have put in a new plug,
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Nov 22, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
44 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
