Question about HP Officejet Pro L7680 All-In-One Printer
When printing in black ink, the Officejet Pro L7680 leaves small gaps in a line across sentences and layout at equal distances of about 3/4 inch. Please advise.
    President:
  • 2,571 Answers
Sounds like you need to do a head clean, and run the align tool
Posted on Sep 04, 2010
How do I clean HP officejet Pro L7680 All pictures have severe vertical lines??
Have you tried the "clean print head" option in the HP Officejet Pro software on your computer? This will often fix verticle lines. But, it will use a lot of ink.
Nov 04, 2014 | HP Officejet Pro L7680 All-In-One Printer
My hp officejet pro l7680 all-in-one printer started printing with black streaking lines. I switched paper today from 20 lb to 24 lb. Would that make a difference?
No that should not make a diffrence!
Try the Following Steps:
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 27, 2011 | Office Equipment & Supplies
L7680 has been printing perfectly - printed
Yes, you can pop the cover on the right over where the printhead parks, and remove the black/yellow printhead and soak it in about a 1/4 inch deep water for 30 mins or so, you only want the nozzle area on the bottom in the water. However if you are using generic inks it may report a printhead failure soon. After soaking you dab the bottom on a paper towel and look for a solid black line on the towel.
Jan 10, 2010 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
My officejet pro l7680 is printing with words
if the ink level is more than half then try to clean the cartridges and the contacts on the printer with a lint free cloth and from printer options as well..
on printer..
press setup button > go to tools > try to clean cart / align the cart and then try to print..
if it doesnt help try with another set of cart.
Oct 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Why am I getting black lines across cards when printing?
Some ink probably got onto the rollers that feed your paper. What you might have to do is run a few cleaning pages through the machine, this can be done through the menus on the device itself under something like "maintenance". If that didn't help, you can look into the printer and gently clean the feed area with a q-tip and rubbing alcohol where ever you see ink. Also, this can happen if you use aftermarket ink or "refilled" ink, they tend to leak more often.
Jul 31, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
180 people viewed this question
Seeker5211
Seeker5211
