Question about Xerox WorkCentre M15i Laser Printer
Xerox m15i se prende copiadora y aparece jam 2, ya cheque el fusor no hay hoja atorada, el actuador esta en posicion correcta en el sensor
5 Suggested Answers
SOURCE: Se reinicia a cada rato
tengo un problema con el ADF de una Xerox Pro 215 cuando quiero copiar algo se van las hojas en fila no juantas sin separarlas una por una que podria ser el prolema alguien podria alludarme
Posted on Feb 27, 2009
  • 239 Answers
SOURCE: Xerox M15i paper gets jammed above the fuser
This machine might have the vertical transport guides broken. The tips break when the white plastic guides are stained yellow.
You may need to have Xerox come out to do the repair, there is extensive work involved in replacing the part and other parts as well. You would need to make sure you have ordered the correct parts for this specific model.
Posted on Oct 17, 2009
Smith-alone
  • 360 Answers
SOURCE: xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Posted on Jul 19, 2010
SOURCE: cómo cambiar el fusor de la xerox m118 y
I need a card red to be used in the Xerox M118 with connection RJ45, wich I can get, model or any specificacion
Posted on Jul 20, 2011
Se enciende la luz del tablero marcada conel 5
No es muy claro; estoy adivinando. Si este es el esquema de su tablero de instrumentos...
El indicador numero "5" se refiere al sensor de presion de los neumaticos.
Esta luz se enciende cuando hay un neumatico bajo condicion de presion . La luz tambien se encendera si existe algun problema con un sensor del neumatico . La luz permanecera encendida hasta que la presion de los neumaticos es correcta o el problema con el sensor se corrige .Esta luz se encendera momentaneamente como una comprobacion de la bombilla cuandose arranca el motor .Cuando el Monitor de Presion de los Neumaticos Light Warning esta iluminado, uno o mas de tus llantas estan considerablemente desinfladas Usted debe detenerse y revisar la llanta lo antes posible ,para inflarla hasta obtener la presion correcta, como se indica en los neumaticos (cartel de informacion del vehiculo). La Ccnduccion con neumaticos no significativamente inflados lo insuficiente hace que el neumatico se sobrecaliente y puede conducir a la rotura del neumatico.
Las llantas desinfladas tambien reduce la eficiencia del combustible y la vida de la banda de rodadura de los neumaticos, y puede afectar el manejo del vehiculo y capacidad de frenado. Cada llanta,incluyendo el de repuesto , se debe revisar mensualmente cuando frio y ajustado a la presion de inflado recomendada como especificada en la etiqueta del vehiculo.
Suerte.
Nov 15, 2013 | 2005 Jeep Liberty
Tv samsung no enciende solo se escuche una oscilacion, chasis cl17k10mjzxxax
porfavor pregunta in el clasification para TV ,esta es los coches e segura niguno de nos altras mechanics sabe esta
Mar 20, 2012 | Cars & Trucks
Se ha encendido luz averir de motor pero no hay error en el checken gin.
pues disculpe que no entiendo lo de averir pero si tiene la luz del check engine y no hay codigo,
solo le esta indicando de checar cosas como el nivel de aceite, de antifreeze, de winshield fluid, o de algun tapon que esta abierto o que ya no cierra bien como el de la gasolina, el de radiador, el de el aceite o alguna vacuum hose desconectada, suerte! Tambien cheque todos fusibles
Aug 01, 2011 | Saab 9 3 Cars & Trucks
Nececito saber poeque se premde se prende una senal de abs se prende
tiene que ser que el sistema de abs tiene una falla.puede serr un sensor de velocidad que no esta trabajando bien. hay 4 sensores de velocidad en carros, trokas tienen 3 2 adelante y uno atras.lo que tines que hacer es llevar el carro a un taller para que te hagan un diagnostico electrico de el abs sistema,para sacar los codigos de la comptudaora para saber qual sensor de el sistema esta fallando. otra causa facil es liquido de frenos puede estar bajo de nivel o un bombillo de las luces de frenos quemado... suerte astaluego parse
Apr 09, 2011 | Ford Excursion Cars & Trucks
Cada ves que predo mi TOSHIBA e-studio202L me aparece error c440
tienes un problema en el area del fusor, lo puedes resetear siguiendo estos pasos:
1.- prende la maquina presionando 0 y 8. espera unos 5 segundos hasta que la copiadora haga un sonido y prenda en test mode
2.- escribe la numeracion 400 y presiona start.
3.- te debe de aparecer un numero de error, para resetearlo solo escribe 0 y dale set o start.
4.- apaga y prende el equipo normalmente y has pruebas funcionales.
si tu equipo sigue marcandote problemas vas a necesitar reemplazo ya sea de las resistencias termicas y el sensor de temperatura, algun fusible o alguna tarjeta controladora de alto voltaje.
Suerte...
Mar 15, 2011 | Toshiba e-Studio 232 Black and White...
APARECE EL CODIGO C6020 Y NO PERMITE SACAR COPIAS
El codigo C6020 significa que hubo sobrecalentamiento en el Fuser. Si Ud. es tecnico en copiadoras, cheque la resistencia del THMS, ien caso de ser 0 ohms, reemplace. De otro modo, puede que la fuente de poder esté dañada. despues de hacer reemplazo de piezas, resetee la copiadora con el codigo U163.
En caso de no tener idea de que estoy hablando, le recomiendo solicitar servicio tecnico para la computadora ya que es un problema serio en el equipo.
Dec 07, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Fotocopiadora Toshiba E.352, saca manchadas las copias en ambos extremos superior e inferior, pág. tamaño carta.
Lo mas seguro es que el area del tambor o el fusor ya necesiten un mantenimiento, puede ser solo limpieza o lubricacion hasta un cambio de refacciones por desgaste.
Sin embargo te dare un tip, si tus problemas son solo en las partes superior e inferior, cambia el tamaño de papel carta de LT LTR, es decir, de posicion vertical a posicion horizontal, y programa este nuevo tamaño en la copiadora desde el boton de userfunction, user, drawers y selecciona el nuevo tamaño.
Suerte y recuerda que este tip es solo temporal, considera de todas formas el mantenimiento de estas areas mencionadas
Nov 26, 2010 | Toshiba e-Studio 350 Copier
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Quisiera saber del Nissan Pathfinder Cual es el color del cable de la posicion de la llave de contacto en el CAC gracias un saludo
hola yo no se mucho de carros, te envio esto ya que si quieres tener muchas soluciones intenta escribir tu problema en ingles ya que en esta pagina no hay muchos usuarios que hablen espanol
Sep 19, 2009 | 2005 Nissan Pathfinder
Xerox WorkCentre M15i Laser Printer Logo
111 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
