Question about Waring Pro Juice Extractor - Black/Stainless-Steel
It was working just great and then I shut it off and it won't turn on again.
In the middle of juiceing, the machine abruptly stopped.
Some juicers have an automatic shut off in them that prevent the motor form burning out.
When mine shuts off, it invariably means it got backed up and some produce in on the blade or in the shoot..clearing that out and then turning on with mine --the juiceman turns it back on.
On my vitasmix and garbage disposal it has this motor saving feature but there is a little button ypou must hit to rest it. sometimes it comes right back on when the button is hit but sometimes waits as the motor is not sufficiently cooled down and will come back on when a short time passes.
Maybe juicing less stuff at each push will help. Mine tends to do this when I am juicing very rapidly and jamming stuff in or when something extra hard is in there and the motor overheats trying to cut it perhaps smaller pieces might help if the produce is hard or very fibrous.
Mar 02, 2015 | Juicers
Why won't my Jack La lanne's come on and it's new never been on
If there is not a flaw in the product itself it could be a problem with assembly or that the locking bar is not locked in place properly. The juicer will not operate if the locking bar does not click in to place in to the grooves on both sides of the lid.
Jack LaLanne has several HowTo videos posted that would be worth reviewing:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
You are also able to download a manual which includes illustrated assembly and disassembly instructions:
http://www.powerjuicer.com/power-juicer-manuals.php
If you are unable to lock the locking bar in place it suggests that some other component has not been installed in the correct position. Review the assembly instructions to make sure all pieces are properly positioned.
Thank you for using FixYa!
Oct 15, 2011 | Jack Lalanne Power Juicer 250 Watts
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Sep 03, 2011 | Omega Juicers
Hi- I wanted to use my juicer again after not having used it in at least 2 yrs. Last time (which I can't remember!) I used it, it worked. This time, all loaded up with veggies, when I turned it on it...
Just looked at mine because I thought there also might be an interlock switch
where the latch arms snap shut. There isn't one, at least on this one. Yours
might be a newer edition, so make sure the latch arms are fully seated and
snapped closed. You can also call Omega at 1 800 633 3401 and run it by
them. The reset switch should be in the pushed in position, it will pop out if
it's tripped.
Apr 29, 2011 | Omega 1000 Juice Extractor
My juicer keeps shutting off after less than 30 seconds
sadly FIXYA has no idea if you can return it or not as defective unit . check with place purchased
Nov 12, 2017 | Jack Lalanne Power Juicer (Stainless...
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Waring Pro Juice Extractor - Black/Stainless-Steel Logo
Top Waring Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Waring Juicer Expert? Answer questions, earn points and help others
