Question about HP Photosmart 2575 All-In-One InkJet Printer
Message error.Oxc 1ab0003 hp 730 lib_micci2_tango.c\r\n coment résoudre ce problème,afin de profiter de mon imprimante de type: hp photosmart 2575
5 Suggested Answers
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
SOURCE: Error:0xc1ab0003
how can this be fixed
Posted on Apr 20, 2009
SOURCE: lcd screen is flashing error:
Please try the following steps:
Make sure unit is plug directly into a wall outlet and not connected to any power strips or surge suppressors
Note : Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Your printer should be back in a working condition after this. Let me know if this has been of any help. Thanks for using Fixya.
Posted on Sep 09, 2011
Je viens de recevoir mon imprimante MG 6150 et lors de la mise sous tension, le message suivant apparait: 6A81 printer error has occurred. Turn off power then back on again. If problem persists, see the...
Bonjour nduvignac
J' essayerais de d?sinstaller puis de r?installer le pilote . D?branche l' imprimante pour ces op?rations , relance ton pc apr?s installation et reconnecte l' imprimante . Si le probl?me persiste , il faut retourner chez le vendeur avec l' appareil et le ticket de caisse .
Cordialement ,
fanaudi .
Jun 30, 2011 | Canon MG6150 Printer
Cartouche couleur non reconnue
Je ne sais pas ce que l'imprimante est d'encre ou laser, mais si foosesti cas ambnele refilate cartouches (remplissage) est susceptible de d?fendre ce probl?me ou si la cartouche est neuve ? monter la cartouche ? cartouche defect.incearca anciens dans l'imprimante si elle reconna?t les nouveaux est d?fectueux
May 04, 2011 | Office Equipment & Supplies
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Mon pc compaq ne peut pas demarrer il me faut une disquette de diagnostique et je ne possède pas ce disque que puis-je faire?
Acc?der au site de Compaq et de recherche pour le disque en«soutien». Si la lecture en anglais est un probl?me, utilisez Google translate. C'est ce que j'utilise pour r?pondre ? votre question.Essayez aussi 4shared.com. type dans le diagnostic Compaq et voir ce que vous trouvez.
Jan 15, 2011 | Computers & Internet
Pas de contacte entre mon ordinateur
Je suis d?sol?, veux-tu dire que l'ordinateur ne peut pas d?tecter l'imprimante?
1. Assurez-vous que vos pilotes d'imprimante sont install?s.
2. Cliquez sur D?marrer-> Panneau de configuration, et d'ouvrir le Gestionnaire de p?riph?riques Syst?me->.
3. Assurez-vous que l'imprimante est connect?e ? l'ordinateur, et qu'il est branch? sur une prise murale qui fonctionne. Allumez-le.
4. Gestionnaire de p?riph?riques Watch, pour voir si elle change / ajoute votre nouvelle imprimante. Si c'est le cas, faites attention ? l'indicateur de p?riph?riques (si l'?l?ment est un code de couleur jaune), et un clic droit sur elle-> choisissez Propri?t?s pour v?rifier l'?tat du p?riph?rique. Il devrait vous donner de plus amples informations s'il ya des probl?mes.
5. Si le Gestionnaire de p?riph?riques ne d?tecte pas l'imprimante, essayez un autre c?ble USB. Si ce c?ble ne fonctionne pas, vous devrez contacter le fabricant de votre imprimante pour le service, que l'imprimante peut ?tre bris?e.
Dec 28, 2010 | Dell 926 All-In-One InkJet Printer
Plus de lecture sur mon MAC
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur
Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la
fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails
de vous. Mais, au moins à vous diriger dans la bonne direction.
Tout d'abord voici le lien pour votre externe LaCie USB 2.0 500 Gig
Disque dur pour plus de soutien de LaCie:
Lien:
* LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Hard Drive Support
En outre, si, pour plus de soutien pour des problèmes avec ce disque dur, y compris si nécessaire d'avoir à reformater votre disque dur, voici le lien:
Plus de dépannage pour votre LaCie externe USB 2.0 500 Go HD pour Mac.
Si vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
Observe,
-Mactechtrainer
Jan 30, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
Sep 27, 2009 | Apple iPod classic MP3 Player
HP Photosmart 2575 All-In-One InkJet Printer Logo
328 people viewed this question
Seeker5211
Seeker5211
