I have a 46" DLP TV, I have sound but no picture. But I can play a DVD, and it works fine.
  • georgegolff May 11, 2008
    The DVD works fine, but TV does not
    President:
  • 2,712 Answers
Adjust the television controls, following advice in the manual. Incorrectly set controls can cause problems like sound but no picture and picture but no sound.
Posted on May 11, 2008
  • Swilin Sampson
    Swilin Sampson May 11, 2008
    Improper input signals/cables can also cause this problem.
    Try unplugging the TV from the mains. Also undo all cabling from the TV. Wait about 10 minutes, then holding the power button on, plug in the TV to the mains. Next, replug all cables and se if the TV works.
    Should you still have an error, it could be a problem with the internal circuitry, for which it is best to get a professional to take a look. Or if its under warranty, best call the manufacturer or the point of purchase.
    Hope that helps..
  • 3,037 Answers
Does the dvd have picture when playing or no picture no matter what?
You can try switching cables.
Do you know if the screen is on?
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    ok, so then the problem would lie on your input from your cable, dish, or antenna.
    Try a different cable for that input which is not running through the dvd player correct?
    Otherwise if a different cable doesn't work, then you may have a loose connection inside which then I would open up the tv and follow the input to the board and see if anything is broken or burnt.
    Let me know what you find. thanks
I have a loud buzzing noise on my Toshiba DLP 46" projection TV. It is not the fan, it works fine. In fact the TV works great and has a good picture. The buzzing used to go away after awhile. Now it...
In some cases the buzz is external. The vibration of the unit may just cause a tray, flat surface, or other surrounding attachments to rattle and buzz. Look for anything that may be loose or laying on or about the TV.
Dec 09, 2014 | Toshiba 46HM94 46" DLP Projection TV 46" -...
Samsung DLP TV no picture or sound 2 weeks old lamp
Hello, DAvid43, what model is your Samsung DLP tv?
Jun 01, 2008 | Televison & Video
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung 46" DLP TV no picture or sound
Replace the TV, the cost to repair is about what new costs.
May 18, 2017 | Samsung DLP HL-P5663W 56" TV
Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
May 30, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
