Question about Toshiba Satellite A105-S4344 Notebook
My Satellite A105-S4344 trackpad cursor freezes after startup and I cannot get it to release. It moves until my virus control (ESET) program comes on, which is right after start up, so I cannot use it to do anything. I can only move the arrows to highlight a box option, so i can re-start the computer. The trackpad had been lighting up spontaneously, and that was freezing the trackpad. I unfroze the trackpad by hitting some of the F buttons around F7, F8, F9, and the trackpad would eventually lose its highlight and the cursor would unfreeze, but this last time it didn't. I cannot do anything with my computer. What can I do?
  • 6 Answers
SOURCE: DVD broken - How to replace it
I found this on the toshiba website http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb35&url=&dialogID=45113241&stateId=0%200%2045111928
Basically it says 'If the internal CD or DVD drive is removable, it's usually secured in place by a locking switch and a separate eject switch / lever on the bottom or side of the computer.'
I couldn't find a decent manual with pictures, hopefully this helps
Lee
Posted on Jun 26, 2008
AvioriX
  • 689 Answers
SOURCE: need drivers toshiba A105-S4344
Hi Anil
I believe your Unit has Intel Ethernet LAN Adapter. You can get the latest version from Toshiba support website as linked below.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?origin=new&ct=DL
Good Luck
Posted on Nov 12, 2008
info2u
  • 596 Answers
SOURCE: how do you install ram in a toshiba a105-s4344 laptop
I take it that you already have the correct RAM you need. Wiith that, power off your notebook, unplug it, turn it over and your will see the larg cover closer to the right of the notebook. Unscrew the screw to release the memory cover and place it to the side. Be carefull with static when handling your memory card, install the card into any open slot in your notebook. (The memory card will go in the slot at a 40 degree angle and then 'snap' down into place. Replace the memory cover (the large piece you took off at the begininig.) power up you notebook and the new memory should be registered and ready for use. Good Luck.
Posted on Feb 02, 2009
sach3000
  • 51 Answers
SOURCE: Screen freezes,cannot click on anything although I
It may be Processors Time is critical. Anything programm run and complete more resources.
1. Run TaskManager, amd see your process. Find this programm, and kill her process, or her tree process.
May be viruses, or mailware...
2. Your PC its very hot: Clean cooller by procesor.
3. HardDisk is freeze system. May be, make one's appearance "bad blocks".
Posted on Nov 08, 2009
chaistars
  • 172 Answers
SOURCE: had to put in a
hi,
you can download the drivers from this website
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1467729&rpn=PSAA8U&modelFilter=A105-S4344&selCategory=2756709&selFamily=1073768663
hope this help =)
Posted on Sep 07, 2010
Cursor at times will jump to another place on screen is this a virus?
Possibly. Run Microsoft Essentials the free antivirus programme that appears to work and is free.
Sep 03, 2012 | Toshiba Satellite A105-S1014...
Cursor on my toshiba sattelite is locked
Hi
This is not automatic lock but you have turned off the trackpad
Hold the Fn key and press F9 key this will re-activate the mouse and then you can use it.
It is provided to turn off because then you type if your palm touch the trackpad the cursor will move and you may start typing somewhere else.
DO RATE MY SOLUTION.
Jun 29, 2011 | Toshiba Sattelite A105-S2051 Notebook
I have a Toshiba LapTop Windows 7 My granddaughter pushed keys and now i can't get the cursor to move. I have tried shutting down and it is still frozen in the middle .
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
I dont have a restore cd
You can download all the drivers you need here>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jul 07, 2009 | Toshiba Satellite A105-S4344 Notebook
My toshiba a105-s4344 has a line threw the screen where the top is darker than the bottom by alil bit and when the screen moves around the screen flashes and goes nuts what do u think the problem is the...
The problem with Lcd screen is that if you see line through them there are three possibiltys 1Your cable connection from the laptop to the screen is loose 2 the inverter is failing which mostlikly you will see backlite flashs and then blank screen or pixcels seem to get lost and return 3 bad screen pixcel lost in hole sections or line or lines than a total lost of screen chech all the connections first .connect a monitor to the laptop and see if you have the same problem if so it may be the video card on the board
Mar 25, 2009 | Toshiba Satellite A105-S4344 Notebook
Screen freezing
with AC power cord plugged in
do a virus scan
in add/remove uninstall any programs you no longer use.
Do a windows update
then do a disk defrag
please let me know if this has solved
Feb 15, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite laptop A105-S4344 graphic card
you should be able to change your graphic
( maybe just not showing )
but first I would check my device manager and see if your
expansion pack shows in there if so update driver
and when you installed the graphic did you do it using control panel add new hardware
Jan 21, 2009 | Computers & Internet
Toshiba Satellite A105-S4344 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
