Question about Creative Labs Zen Digital Media Player
Won't turn on.
My creative Zen won't turn on, or respond with my USB cable either.
Can you be of any assistance?
Thanks.
  • 13 more comments
  • Anonymous May 13, 2008
    HELP MEEEEE
  • Anonymous May 24, 2008
    This is ****
  • MissTeee May 24, 2008
    16gb Creative Zen arrived yesdy from amazon. Turned on briefly on receipt to check ok and then shut it down again but unit now completely dead. Despite having hooked it up to usb hub on pc to charge - no blue charging light, no battery signal, windows says there is a malfunction with the device attached and lists it as 'unknown device', though I have installed the software first as instructed. Old Mp3 - microphoto functions immediately under same circs. Perhaps I am panicking too soon and will charge but just now all the new zen is doing is becoming warm to the touch. Feeling suspicious...Any help would be great, thanks, Miss T.
  • Damma32 May 26, 2008
    My blue light is on when hooked up to the USB on my laptop but the Zen is unresponsive. It doesnt' say it's charging and the screen is black. When I unplug it it remains black and unresponsive, with the blue light still on. My husband plugged it in to charge and then put my laptop on hibernate. Basically, nothing after that. The USB connection says there are no drivers for the unknown device. I have had no problems till now. Had it for 3 weeks. Creative Zen 8 gig.
  • Kirk Witzberger
    Kirk Witzberger Jun 02, 2008
    I just received the Zen, charged it, and downloaded music files from multiple poorly organized sources. Sometimes immediately, sometimes after a song or two it freezes and I have to reset it. I wonder if it is because it finds more than one music file with the same name. Anyway, unless I can find a way soon to keep it operating I'll be sending it back.
  • natepeterson Jun 13, 2008
    my zen ran dead a while back and i went to turn it on after a few minutes of charging, but instead the screen went blank and now i have to reset it after a period of time to even get the blue light to flash when charging. after about twenty minutes of charging it stops flashing and i try to turn it on. is there any way you can help me reconnect to my music?
  • Anonymous Jun 16, 2008
    My Zen won't turn on. I plugged it in to the back of my computer for 6 hours and it still doesn't work.
  • Anonymous Jun 21, 2008
    i plug my zen into the back of the computer,the blue light only appears and the screan remains blank.previous to this when the screan turned on it showed that i had a firmware problem.can you help with either problem???
    many thanks
  • mcgrathdavid Jun 21, 2008
    I pluged my zen into the computer and the blue light appeared but the screan did not turn on.Previos to this when the screan turned on a firmware problem occured.Any solutions to either problem would be much appreciated
    many thanks
  • Anonymous Jun 22, 2008
    Just got it, wont turn on.
  • 11zen Nov 28, 2008
    my zen won't turn on or charge. i charged it and now it does not respond. i tried to hit the reset button and that did nothing. HELP!!!!!!!
  • a7x_122992 Nov 29, 2008
    Dosent turn on nor does it resopnd with usb and my computer doesnt even detect it it worked perfectly fine before i had to resest while it was docked (wasnt plugged in the usb when it said docked)
  • Anonymous Dec 04, 2008
    its broke
  • smcg82 Jan 02, 2009
    i got it today, turned it on, transfered some files. then hey presto, the screen blanked out and remained frozen despite my attempts to reset it.
  • Manghuel Jan 03, 2009
    my player does not turn on when i flip the switch or will not give the "pluge in" sign when plugged in. What can i do?
I had exactly the same problem as Damma32.
This solved the problem:
I plugged the ZEN out from the PC and pressed the reset-button, then pressed the play-button while turning it on again. when the creative logo appeared on the screen I released the play-button and a recovery-meny appeared. I used the clean-mode, which fixed the problem.
Posted on May 28, 2008
The same thing happened to me. I tried everything known to man except something that is now very "duh" when I think about it (and the "duh" is directed towards me, not to anyone else). I always used my player in the morning at the gym, then in my car on the way to work. Once at work, I plugged into the usb port on my laptop and let it charge all day. No problems. Then I would listen to it on my way home from work in the car, and then tuck it into the glove box for the next morning at the gym. I did this 5 days a week for about 7 months. Then, I took a week off work. When I would get home from the gym, I never thought about plugging it into my lapto nor did I charge it up on my home pc. I just left it in the car. So, needless to say it died. And so, since February I have been fussing with it because it won't charge. I even bought a wall charger, to no avail. And then last week, out of frustration, I emailed Creative because I tried everything suggested and even things that were not suggested. And I got their stock reply. Plug it in, leave it for 6 hours, call us in the morning. Nothing, nada. Then I re-read their reply and finally noticed what I had been missing. Plug it into the BACK of your Desktop PC. Not the front port, not the ports on your laptop. The BACK of your desktop PC. Huh. So I tried it. And viola! Instant recognition from the player and the computer and (after 6 hours) now I am happily not listening to the radio in my car or using my old dell dj ditty at the gym. I still charge it on my laptop during the day. But at night, when I get home, I now remove it from the car and plug it into my wall charger. Basically, what I learned is that laptop usb ports and the front port of desktop pcs have very weak power capabilities. And that I need to read instructions a little better.
Posted on Jun 03, 2008
I had solved my problem by the time Maush posted, but I want to say that I did this as a last resort and it did indeed work! I took my blackberry charger which fits my Zen player and plugged in my Zen overnight (any similar phone charger will work). I got no response from the player at this time, but the little blue light remained on but no other response from the player. I knew it would charge it since I had tried to charge it this way before the player went blank and it had showed the charging icon on the player. I wanted to make sure it was charging since it didn't show it was charging on my laptop and the USB didn't recognized it at all. In the morning I unplugged the player which still showed blank and unresponsive, and with a needle I pushed the RESET button on the player and it worked. I had prepared myself to lose all my data, but instead it turned on like normal. I didn't lose any data and it showed a full charge. I hope I don't have this problem again, but if I do, I assume this method will work again. It was unresponsive for three days before we resorted to the RESET button. I have a Zen 8 gig. Thanks to Maush for posting his/her fix.
  • Damma32 Jun 03, 2008
    In response to MissTeee and as a follow up to Flash74, I had the same exact problem as MissTeee and returned the first Zen I bought to the store. I then had problems as posted with my second Zen after 3 weeks of use. It seems that battery power is the root of all problems. When I got the first Zen it turned on just fine, we followed the install and set up, but were unable to finish setup because the Zen just died. It was totally unresponsive and we had charged it on the laptop USB but not for the full 6 hours. We assume the Zen was defective and returned it. When I got to the store, the technician plugged it in to these huge PC's they do systems checks on for returned merchandize, and sure enough, the Zen turned on at the store and started charging. It had been completely unresponsive at my house for two days, but I was charging on the laptop USB. I thought for sure that Zen was a lemon, but in retrospect, having to charge it on a PC back-USB port may be solution and cause of the problem. I now charge my new Zen on my Blackberry phone charger and have no problems. I don't let it get to red on the battery power either just to be safe. Hope this helps.
Stupid question folks:
If I didn't charge it properly at first (used a laptop) then might this be why it's not holding a charge from my wall plug charger? I am leaving it plugged into my PC tonight - should that straighten things out? It was running out of charge after one day's play.
scot
Posted on Oct 10, 2008
This is amazing.
I've been fretting because I have to endure a drive from the UK to Paris next week; and my Zen had frozen. I couldn't do anything, and my brother's had the same issue (Zen v+). Thank you so much. I plugged it into the back of the computer and IT WORKED!
Posted on Jun 23, 2008
Do not charge it with your PC. I have a Zen 32 and it conked out on me. I plugged it with my phone charger and it came back to life.
Posted on Jun 12, 2008
For about 1 week my Zen would freeze once I would push the play/pause, forward, back, or the select button. I felt like throwing it against the wall and regretted buying it. Then I found this website, did what Maush suggested. Once the recovery menu appeard I went to reboot and wa-la!! It works again!!
Posted on Jun 10, 2008
Ok i had the same problem because my zen would not turn on. I had connected it to a mac laptop and then it just would not turn on. When i connected it to the usb still nothing. It wouldnt come on and the computer would not recognize it. I dont know how it worked but just by hittin reset on the player, it came on. All the songs and stuff are still on it and now its great. Hope it helps!
First the screen became frozen,then buttons didn't work,i tried to turn off and the screen freeze again while shutting down..i left it open about 15 hours,then it was turned off but i couln't turn on again,i connected it on the usb port but pc didn't recognize it and the blue light didn't turn on.also the screen is pure black.what can i do?
Posted on May 15, 2008
My computer won't read my creative vision:m zen 30gb and i cn't find installation cd
http://support.creative.com/Products/ProductDetails.aspx?catID=948&subCatID=958&prodID=16002&prodName=ZEN%20Vision:M%2030GB&subCatName=MP3%20Players&CatName=Entertainment+Devices+%2f+MP3+Players&VARSET=prodfaq:PRODFAQ_16002,VARSET=CategoryID:948
Oct 19, 2012 | Creative Labs ZEN Vision:M Digital Media...
I got water in my creative zen and it won't turn on. Is there any way of fixing this?
Probably not.
Remove the battery and place the player in a warm sunny dry place for several days until it drys out completely. Replace the battery, charge it and the see if will work.
Aug 20, 2012 | Creative Technology ZEN Mozaic Pink (4 GB)...
Creative zen micro won't read my music
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jul 16, 2012 | Creative Labs Zen Micro MP3 Player
My Zen seems to be totally dead after loading it with mp3 tracks. I've recharged it to no avail, it won't switch on or reset, and it is not recognised by my computer when connecting via a USB...
hi your not the only one i got mine for my birthday 8 weeks ago and now it dont work its like its dead this zen v plus to is like not the best thing to have all i see is people like me having some sort of prob with it
Sep 20, 2011 | Creative Labs ZEN V Plus MP3 Player
Computer wont recognise my zen Vplus
replace or usb cable...f not chek usb port of ur unit
Jun 30, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen won t connect
http://cameras-and-mp3-player.free-driver-download.com/40562/Creative-ZEN-4GB-8GB-16GB-MP3-Player-Firmware-1.13.01-Windows-XP(x32-x64)-Vista(x32).html
Mar 26, 2009 | Creative Labs Zen V MP3 Player
Zen problems
it may be in a low power state, try a different usb cable and hook it up to a desktop computer (laptop ports are sometimes not powerful enough to charge the battery when it is in a low-power state). I had this exact same problem and that fixed it!
Also check out creative.com/support and look at their support forumns
Jul 12, 2008 | Creative Labs Zen Digital Media Player
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Digital Media Player Logo
695 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
