Question about Prosonic PLTV-30 30 in. HD-Ready LCD Television
Code of prosonic TV - Prosonic PLTV-30 30 in. HD-Ready LCD Television
  • carlos monteiro Sep 22, 2013
    i would like to know the code for remote control of b23d6d tv lcd prosonic.
How much the universal remote?Can i unlock the TV Prosonic DFT/2616 with any button on TV?
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Aug 08, 2016 | Universal Televison & Video
Prosonic tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 10, 2014 | Prosonic Televison & Video
I have prosonic tv.is in stanby child lock it can be turn on.what can i do Now
Write your answer...how do I remove prosonic child lock it asking for password and don't have d ideal at all
Oct 28, 2013 | Prosonic Televison & Video
Hi i have a prosonic television and i want to play my computer but i am not sure how to find the AV button?
first make sure you`ve connected the AV cable from the tv to the pc and check carefully in the remote and press the tv button if AV is not indicated
Sep 16, 2011 | Prosonic Televison & Video
On the rear of a Prosonic TV there are an audio out, coax connection for an amplifier. How can this plug / connection support an amplifier with a stereo signal? Make: Prosonic Model NO.:PBT-26001
It's a digital signal, basically, it's sending left and right out as 2 seperate frequencies and needs to connect to a suitable amp to "decode" the signal.
May 18, 2010 | Televison & Video
Prosonic manual child lock will not remove. I have forgotten my code
The factory-default password is '1234'.
Clear All—Resets all V-Chip settings to factory
defaults (unblocked)
Feb 25, 2010 | Prosonic PLTV-30 30 in. HD-Ready LCD...
NEED CODES FOR PROSONIC DVD PLAYER
I do not see any codes for a Prosonic Dvd Player in the URC-3021 manual. Have you tried searching through the remotes codes to see if any are compatible? Here are the manuals instructions:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Aug 30, 2009 | One For All URC-3021 Remote Control
Philips universal remote codes
Here are the remote codes for virtually all TV sets; follow the instructions for setting up the remote. You only can use the remote for ONE device:
https://wabash.com/wp-content/uploads/2015/11/ADB-Programming-Guide.pdf
Sep 21, 2017 | Philips Televison & Video
Prosonic PLTV-30 30 in. HD-Ready LCD Television Logo
421 people viewed this question
Top Prosonic Televison & Video Experts
Jaime Hernandez
rugby prop
Are you a Prosonic Televison and Video Expert? Answer questions, earn points and help others
