Question about Toshiba Satellite 2410-S203 Notebook
I have a toshiba 2410 laptop and cannot read the product recovery cd-rom that came with it. I can read other dvd/cd ok, and can read this recovery cd in a different computer. this has happened before. Is there only a set number of times I can use a recovery cd? Will I have to order the recovery cd's again?
SOURCE: matshita dvd-ram uj-841s I/O device error
go to 'device manager', look for CD/DVD and ensure that the driver is functional for this specific model you mentioned. also check Toshiba website for any device updates for this unit.
Posted on Jun 16, 2008
YourTech
  • 63 Answers
SOURCE: Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Posted on Aug 26, 2008
  • 97 Answers
SOURCE: toshiba satellite cd/dvd-rom
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Posted on Sep 16, 2008
  • 13 Answers
SOURCE: Toshiba Laptop Satellite 1415-S115
If you contact Toshiba with your computer information they, usually, will sell you recovery CDs. You can find excellent, free DVD software at download.com
Posted on Mar 23, 2009
NitrusInc
  • 326 Answers
SOURCE: how do you remove the cd rom from toshiba
In order to change your DVD drive you need not take your system apart, there should be one screw on the bottom near your drive to remove which will allow you to slide the drive out.
Should you feel more comfortable with a picture guide for a similar model, here's a link
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
You can do it, don't get discouraged.
Posted on Apr 17, 2009
How do I actually start to format my Toshiba Satellite M100? I have only a product recovery DVD-ROM.
Hello
Just put the recovery DVD in DVD ROM drive and boot system from DVD ROM, by changing the boot options from BIOS, rest will be done by computer itself.
Hope this helps.
Good Luck
Jan 18, 2011 | Computers & Internet
Advice me how to install OS to Toshiba s2410, 304
Get hold of a external cd or dvd-rom, press f12 at start to bring up boot menu and boot with usb cd-dvd-rom.
Jan 19, 2010 | Toshiba Satelite 2410 Notebook
I need to use recovery disc on my laptop 1410/2410 Toshiba
Power down the notebook, as soon as you power it up continually keep tapping on the 0 (zero) key. You should see "Hard disk drive recovery mode"
The "recovery mode" will bring your notebook back to factory default settings so please save your data because you will lose it.
In case Toshiba changed the older models,(which seems to be the case) here is a link to a pdf file from Toshiba
http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
Hope this helps.
Nov 10, 2009 | Toshiba P000355040 - Satellite 1410 and...
How do i restore my toshiba laptop with the recovery cd, where can i get the recovery cd
Recovery CD is saved as a recovery partition on the system, which needs to be written/burn onto the CD/DVD.
Steps to create a recovery disc (Insert a blank DVD in the CD/DVD rom) -
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
If you dont have the above options, you need to call the tech support and ask for the recovery disc & it will be shipped to you.
Jul 09, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
Download new driver files of pioneer dvd drive fron internet.
Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
Recovery cd
See How to Create/Use a Toshiba Recovery CD/DVD-ROM
and toshiba recovery cd - CD & Download Versions Available
Alternatively you can get a recovery cd contacting the retailer were you bought the computer, or contacting Toshiba.
Oct 15, 2008 | Toshiba Satellite 2410-S203 Notebook
Detects CD but not DVD
Hi Chopadepve,
Please try this method but be more careful during working out on it:
Since your DVD drive reads cd's, but not dvd's It shows that the hardware works fine. Now we need to Edit the Registry to fix this problem.
1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters" in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) Reboot PC
Windows should automatically install a clean ROM drive after the reboot otherwise Open the device manager window and click "scan for hardware changes". DVDs just read fine if you have the correct DVD decoders.
If no luck then might be DVD read head wiped out.
Regards
ELLIN
Sep 12, 2008 | Computers & Internet
Replacing a dvd-rom drive
go to http://www.irisvista.com you will find lots of information about replacing the parts of Toshiba Notebooks
Good Luck
Apr 14, 2008 | Toshiba Satelite 2410 Notebook
CD-RW/DVD-ROM can not read and CD or DVD
yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Feb 17, 2008 | Toshiba Tecra 9100 Notebook
Missing or corrupt windows\system32\config\system file in XP
sciberteach:
Go in the BIOS, in the boot sequence make your DVD player as the 1st number device to boot from, restart your machine and do follow the article (you should know the admin password to go into the system drive):
http://support.microsoft.com/kb/307545
Note: If you are too overwhelmed then your Product recovery DVD will give you your original OS and all settings back.
Dec 10, 2007 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite 2410-S203 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
