Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W25 When you turn it on the power button in front flashes 3 times and the tv dosent turn on
  • mhb1234 May 12, 2008
    What is a flyback and where is it located at. I had bestbuy look at it and they told me it was the power deflection circuit board and they want about 420.00 for the part and 150.00 in labor
  • rkhart May 12, 2008
    Having the same problem. I looked at the connections and see nothing wrong. The tv will show a green light, then turn off. It does this three times. Any suggestions? Thank you.
  • RCA Master
  • 8,617 Answers
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
Posted on May 12, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    You can get a new flyback at the following link for about 50.00 and they provide instructions and free on line tech support so you can do the repair yourself which takes about 30 minutes from start to finish. Heres the link.
    And here is what it looks like it is located on the far left side of the chassis with a large red wire and a smaller wire coming out of it.
Rca hd d52w25 tv was working fine turned it off when turned on now no picture or sound and power button flashes green
The most common cause of that symptom in that model are the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from the kit contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25 power issues.
Install the repair kit called the CP150, CP120 and CP114 repair kit available from the kit contains instructions on CD also.
May 24, 2010 | Televison & Video
The power button light blinks a few times but no power afterwards. RCA D52W25 is dead. I lightly shook the TV last night and it worked until this morning.
These units are famous for loose solder connections at the high voltage transformer and for bad capacitors in the power supply. Have a repair shop check it out for you. You have to remove the Deflection PCB to do these repairs. Thanks
Oct 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
RCA d52w25 52 inch blinks 3 times off...turns
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Big Blur when i turn the tv on
First of all please check the following things:
Press the TV button. Make sure the TV is plugged in. Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else. Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions. The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Front Panel Block in the Parental Control menu and press OK to uncheck the box. The TV might be performing a periodic diagnostic check. Wait for a few minutes for the TV to turn on.
If still the problem persists then check the following:
Maybe the cable/air function is set to the wrong position. The channel might be blank — change channels. If you’re watching your VCR and it’s connected with coaxial cable to the CABLE/ANTENNA jack, tune the TV to channel 3 or 4 (whichever channel is selected on the 3/4 switch on the back of your VCR). Also check to make sure the TV/VCR button on the VCR is in the correct mode (press the TV/VCR button on your VCR). Check antenna connections. Make sure all of the cables are firmly connected to the jacks. Try adjusting sharpness function to improve weak signals. Closed-captioning might be on. Check Closed Caption in the Setup menu.
Please do rate this solution as FixYa and revert for further assistance.
Jun 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Take the back off the TV look where the wire from the power plug enters the TV. There is a small fuse on the board where the wire plugs into. If that fuse is blown, you have a power supply problem.
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
if the front led blinks 3 times slowly then shuts off its most likely the flyback. Its available at the following link for under 50.00 and they will provide free tech support on line so you can change it yourself takes about a half hour start to finish. You will need Flyback number 259296 Heres the link
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W25 pierre
Possible arching crt. which one red blue or green. HIgh voltage problem could be simple connection ... could be tube.. replacement of crts in these units are generally expensive to say.around 400 for parts and labor
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
