Question about Creative Labs Zen Digital Media Player
It just stopped working . . .
So, I turned off my zen, and got ready to put songs on it. I plugged it into my computer, and then waited for it to turn back on; it never did. I recently and persistantly keep trying to turn it on, but it does not. Is there a way to fix this?
Thanks.
If any extra assistance, email : matthweMOURN@aim.com
You may reset you player by pinning the reset button. I had same problem which got resolved.
Posted on May 18, 2008
I have a Zen Creative MP3 player w/ about 1,500 songs I don't want to lose. Lately it turns on, but won't continue to the regular menu. Just gets stuck on the "Creative" words that show in the screen....
What you need to do is plug your Creative into your computer and backing up all your songs and Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 30, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
My Creative Zen won't turn on or so sizes of charging.
On the bottom is a very small hole. Put a pin in and push, it will start your creative up again.
Mar 09, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen V Plus locked up, will not shut off
After 3 1/2 hours, the battery went dead. I waited a couple of minutes, then plugged it into my computer to see if the battery would charge. It started charging. A few hours later I went back to check on it, and it showed a full battery. I disconnected it from my computer, and turned it on. It came on, but the screen just said "Low Battery". I then plugged it back into my computer, and the screen said "Rebuilding Library". I left it for about a 1/2 hour, and it was done. I unplugged it from my computer, turned it on, and it works now!! Hope this helps out everyone else who has the same problem.
Feb 12, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen m wont turn on
Well, it needs to charge via USB on your computer, so plug in your zen into the computer with the creative usb cord, and let it recharge. It may not necessarily turn on if it's really out of battery, but you can tell its charging when the switch you use to turn on and off, and hold, the light is blinking. After sometime, your Zen screen on the upper righthand corner should show a little battery and be blinking green what stage it's at in its charging. When its done charging the battery icon with be fully green, not blinking, and have a little plug icon inside of the battery icon to indicate that it is fully charged--takes a couple of hours to charge.
If that does not work, check your USB cord to make sure it's not damaged in any way. If it is, you may need to purchase a new one for better connection. And if that doesn't work, then you might need to replace the battery altogether, which I'm sure, if you are still in your manufactuer's warranty, they can do for you. After it is replaced, your zen should be good as new and ready to operate.
Hope this helps. Good luck!
Jul 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Zen V Series mp3 player won't turn on.
Try pushing the reset button with a paper clip while the unit is plugged into the unit. This worked for me.
Nov 07, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen Digital Media Player Logo
21 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
