Question about JVC GR-D270 Mini DV Digital Camcorder
Can I use SDHC memory card on this camcorder? The manual specific SD card.
  • 76 Answers
I have found that on occasion the SDHC cards may work but it will not be reliable. Only use SD cards as your camera isnt made for the SDHC features. I hope this helps.
Posted on Sep 06, 2010
I have a DXG 5B1 HD and need to replace the card. What specific card is compatable?
As per this page:
DXG USA DXG 5B1V HD DXG Sportster 1080p HD Underwater Camcorder
SD Card (Up to SDHC 16GB Class6)
This is probably one of the best you can buy:
SanDisk Ultra 16GB SDHC Class 6 Flash Memory Card Speed Up To 30MB SDSDH...
If you don't need 16GB, you can buy cheaper cards with less storage space.
Jan 29, 2015 | DXG 5B1V HD Sportster 1080p HD Underwater...
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
What card in samsung smx-f40bn/xaa
FROM THE OWNERS MANUAL: Using a memory card (not supplied)
• This camcorder has a card slot for access to SD and SDHC (Secure Digital High Capacity).
• You can use SD and SDHC cards on your camcorder.
- Some cards are not compatible depending on a memory card manufacturer and memory
card type.
May 19, 2012 | Sony DCR-SX40 Camcorder
I have a GR_D90 Camcorder- it will not read the memory card-New 16gig-SD card what shall I do? will the recorder still work if the card does not? where can I get replacement CD-rom for this camcorder?
According to the manual, the GR-D90 works with MMC or SD cards. Your new 16GB card is actually an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into an SD slot, they are electronically incompatible and will not work. SD cards max out at 2GB in size.
Mar 19, 2011 | JVC Everio GZ-MG360 HDD Camcorder
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
Dec 25, 2010 | JVC Everio GZ-MC200 Camcorder
I just purchased 2 new sdhc class 6 cards from ebay. I put them into my jvc everio camcorder and it says "memory card error". Do I have to format them, or are they bum cards? Thanks
I doubt there is anything wrong with the cards. Cards usually come pre-formatted, but you could try formatting them and see if it makes a difference.
However, I expect that your problem is down to compatibility. Many cameras, especially those that are a couple of years old, won't work with SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different. SDHC is not backwards compatible. Unless your camera's manual specifically mentions that you can use SDHC cards, you probably can't. I believe the largest capacity SD card is 2GB. Anything bigger will be SDHC.
Dec 24, 2010 | Cameras
I just bought the Lumix DMC-ZR1 (yesterday April 3rd) When I put the memory card in, and it's blank, the camera reads that the memory card is full....how can I fix it??
In the instruction manual - see links below
  • It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit You can use an SD Memory Card and SDHC Memory Card. •When the term card is used in these operating instructions this refers to the following types of Memory Cards. – SD Memory Card (8 MB to 2 GB) – SDHC Memory Card (4 GB to 32 GB) More specific information about memory cards that can be used with this unit. • You can only use an SDHC Memory Card if using cards with 4 GB or more capacity. • A 4 GB (or more) Memory Card without an SDHC logo is not based on the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 04, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Manual for GZ-MG21U says any SanDisk would work with this camcorder but we got a SanDisk that says SDHC Card but when I insert it and click menu button nothing comes up.
Make sure that the card is not locked. There is a little switch that slides on the card to write protect information on it from accidental deletion. If the card is not locked, it may need to be formatted. I'm not sure if your particular camcorder has that ability or not. If not use a card reader on a computer to format it. It may be possible that your camcorder will not accept an SDHC card. It may only take a SD memory card. The HC stands for high capacity and it may not be compatible, so you may need an SD memory card not the SDHC one. I hope this helps and good luck!
Dec 03, 2009 | JVC Everio GZ-MG21 Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
203 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
