Question about Homelite Mighty Lite Lawn Trimmer
Whipper snipper starts but wont run. The fuel lines have been taken off the carby and replaced . They may be reversed. Could this be the problem. Need a diagam as to which lines go to where
5 Suggested Answers
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
2strokeguy
  • 183 Answers
SOURCE: need exploded view diagram for a zama carby on a
www.zamacarb.com
Zama has a great website. It will show you where to find the series and model number of your carb, as well as a search engine to find the diagram and parts illustration for your carb.
Posted on Nov 04, 2010
  • 100 Answers
SOURCE: hi i need to know what the fuel mixture settings
if u took out the high and low idle neddle valves they need to be reset startin with high
Posted on Oct 25, 2012
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
My still fs36 whipper snipper runs but wont rev out
The strimmer has a small engine and therefore very small fuel passages that are very easily blocked unless a near-surgical cleanliness is observed when fueling and the air cleaner maintenance is up to date and carefully carried out.
In my experience such fuel-related problems are most likely. It is worth checking the spark plug first considering how much easier that would be. In the case of a blackened condition begin by checking the air cleaner for fouling and the cold start for correct operation.
Jul 17, 2015 | whipper snipper Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
24 hp sears tractor 48" stalls after 15 minutes
check for rubbish in your injectors and drain fuel tank,also check air inintake to the carby and make sure its clear, it can somtimes suck in grass seeds into the carby, i use a small fuel filter from a whipper snipper and it works well
Nov 16, 2012 | Garden
I have replaced my ryobi whipper snipper fuel lines and now it won't stay running. What have I done wrong?
I have had exactly the same experience, and then also replaced the primer bulb, messed around with the carby mixtures, but so far it will not run for more than about 3 - 5 seconds! I have yet to resolve this problem.
Feb 26, 2011 | Ryobi Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
Hi i need to know what the fuel mixture settings are on a homelite 26 cc whipper snipper 5 months old i dismantled the carby to clean it .now it starts but wont keep going
starting position for screws marked H and L is 1 and 1/8 turns out from carby for both ...Do not screw in tight otherwise damage to screw will occur
Apr 10, 2010 | Homelite Mighty Lite Lawn Trimmer
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
My fs 45 whipper snipper is starting but running
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Homelite Mighty Lite Lawn Trimmer  Logo
96 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
