Dell 8600 desk top. When I start the computer and get to the screen to enter desktop I get message SAS window:winlogon.exe - application error
The instruction at 0x0170e3e8 referenced memory at 0x0170e3e8. The memory could not be "read"
Options click OK to terminate the program
Click on CANCEL to debug the program
Hi Booty - this might be the Netsky virus. Follow the link below for a removal tool. Read the instructions. If you need help with this just add a comment. If this solves your oroblem please rate this as fixed. If it doesn't help, DON'T RATE YET, just add a comment and I'll help you further. Thanks.
http://securityresponse1.symantec.com/sarc/sarc.nsf/html/w32.netsky@mm.removal.tool.html
Jeff
Posted on May 11, 2008
Jan 19, 2014 | Microsoft Windows 7 Professional 32 bit...
Feb 02, 2013 | Microsoft Windows XP Home Edition
The process "winlogon.exe" runs in the background. Winlogon
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete." Select "Yes" when asked if you're sure you want to remove the program.
hope this helps
Sep 17, 2012 | Microsoft Windows XP Professional for PC
The Windows Genuine Advantage process (Wgatray.exe) is a Windows XP application that checks the validity of your copy of Windows. You will notice a recurring message that reads, "This copy of Windows is not genuine" if the Wgatray.exe finds your system to be inauthentic. After a while, these messages become a nuisance. You can easily block the process and return to your normal computer activity.
Difficulty: Easy
Instructions
Click the Windows logo in the bottom left corner of the screen. Click "Run" and type "taskmgr" in the dialog box. Click "OK."
Open the "Processes" tab and highlight "wgatray.exe."
Click "End Process." Exit the Task Manager.
Open the "My Computer" icon on your desktop. Navigate the following folder paths:
C > Windows > System 32
C > Windows > System > dllcache
Right-click and delete the "wgatray.exe" file.
Open the Recycle Bin and click "Empty the Recycle Bin."
Click "Start" and open "Run."
Type "regedit" in the dialog box and click "OK."
Navigate the follow registry path on the left panel of the window:
HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft >
Windows NT > CurrentVersion > Winlogon > Notify
Delete the folder "Winlogon." Exit the Registry Editor.
Jan 23, 2011 | HP Computers & Internet
Jan 18, 2011 | Dell Vostro 1510 Laptop Computer PC...
Mar 19, 2010 | Dell Dimension 3000 PC Desktop
Jan 27, 2010 | Dell Inspiron 6000 Notebook
May 09, 2009 | Computers & Internet
Dec 06, 2008 | Computers & Internet
Jul 23, 2008 | Computers & Internet
123 people viewed this question
