Question about Asko 24 in. 1805 Built-in Dishwasher
The start switch (right side) not power switch (left side) broke....(below the overlay). I need to replace the switch and overlay. What part(s) do I need to fix the switch. I now have overlay part number. This is for "start" switch... Thanks
  • Asko Master
  • 2,605 Answers
Hello again,
I'm glad I was able to help you earlier with the overlay, unfortunately I'm not sure I can go 2 for 2 because the start switch issue is going to be a little more involved.
The issue is the start switch is actually integrated into the main control assembly,
example...
...hence you may need to replace the entire assembly and...this is the unfortunate part...it is no longer available at most part vendors since Asko no longer manufactures it.
If need be I'd recommend calling Asko USA at 1-800-898-1879 and see if perhaps they can direct you on a location, or you can look at "repairclinic.com" under # 1472725.
I say may because the control itself has possibly fallen away from the white upper plastic case which houses it, ( refer to the image ) thus the switch is not actually being pushed.
Either way will require you to open up the console to inspect it or replace the control if that isn't the issue and the start button simply no longer responds to the command when pushed.
In any event I attached the pdf pages of the parts illustration I have on pc, they may in fact be too small once sent though.
The part number by Asko originally is # 80 706 99-04.
bdff0db.pnthe start switch (right side) not power switch - 0a8ac72.png_mi
Hope you find this info useful, let me know if i can assist you further of course, I will see what I can do.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 05, 2010
Rear window defroster won't work
Locate and test or replace the fuse with a new or known good fuse. Check for a wire on both the left and right side on the rear window glass that connects to the defrost overlay "lines". Make sure they both are connected / plugged in to the connector(s). If these are OK, there may be an issue with the switch / timer that will require tools and more to track down and correct. You'll likely need to use the services of a trusted mechanic in that case.
Dec 01, 2015 | Cars & Trucks
Need diagram
There is a 9 pin near below at the sata socket .
the upper pin 1 and 2 pin in left going right side are for power led light. and the 3 and 4 pin is for power switch.
the lower side are the same position but 5 pins.
lower 1 and second pin is for hdd led, the 3 and 4 pin is for reset switch. forget about the last pin, it must be empty
look like this ::::.
start the count from left to right.
do not start from upper to lower
Posted on Jan 09, 2015
Jan 29, 2014 | Foxconn RS740M03A1-8EKRS2H 2 x Ddr2 Mb
1999 buick lesabre my right signal doesnt blink it stays solid , my left turn signal blinks fine i have to manually blink the right side every turn , i put the hazard lights on and the front left and right...
The easiest thing for you to do would be to replace the bulbs that are on that circuit. You should have one or two bulbs with a double filament, one for the brake and turn signal and one for the tail light.
If that does not fix the problem, someone will need to check the circuit for power from the turn signal switch. It takes all of the lights on one side to make the turn signal flash.
May 16, 2013 | 1999 Buick LeSabre Custom
How to reset a samsung pl201?
.adslot-overlay {position: absolute; font-family: arial, sans-serif; background-color: rgba(0,0,0,0.65); border: 2px solid rgba(0,0,0,0.65); color: white !important; margin: 0; z-index: 2147483647; text-decoration: none; box-sizing: border-box; text-align: left;}.adslot-overlay-iframed {top: 0; left: 0; right: 0; bottom: 0;}.slotname {position: absolute; top: 0; left: 0; right: 0; font-size: 13px; font-weight: bold; padding: 3px 0 3px 6px; vertical-align: middle; background-color: rgba(0,0,0,0.45); text-overflow: ellipsis; white-space: nowrap; overflow: hidden;}.slotname span {text-align: left; text-decoration: none; text-transform: capitalize;}.revenue {position: absolute; bottom: 0; left: 0; right: 0; font-size: 11px; padding: 3px 0 3px 6px; vertial-align: middle; text-align: left; background-color: rgba(0,0,0,0.45); font-weight: bold; text-overflow: ellipsis; overflow: hidden; white-space: nowrap;}.revenue .name {color: #ccc;}.revenue .horizontal .metric {display: inline-block; padding-right: 1.5em;}.revenue .horizontal .name {padding-right: 0.5em;}.revenue .vertical .metric {display: block; line-height: 1.5em; margin-bottom: 0.5em;}.revenue .vertical .name, .revenue .vertical .value {display: block;}.revenue .square .metric, .revenue .button .metric {display: table-row;}.revenue .square .metric {line-height: 1.5em;}.revenue .square .name, .revenue .square .value, .revenue .button .value {display: table-cell;}.revenue .square .name {padding-right: 1.5em;}.revenue .button .name {display: block; margin-right: 0.5em; width: 1em; overflow: hidden; text-overflow: clip;}.revenue .button .name:first-letter {margin-right: 1.5em;}a.adslot-overlay:hover {border: 2px solid rgba(58,106,173,0.9);}a.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}a.adslot-overlay:hover .revenue {border-top: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}div.adslot-overlay:hover {cursor: not-allowed; border: 2px solid rgba(64,64,64,0.9);}div.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}div.adslot-overlay:hover .revenue {border-top: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}6_4_2012_11_48_48_am.jpgTurn The inner bit towards you until it goes in fully then turn it on and it might work. Thats what I did and it worked
Feb 12, 2012 | Office Equipment & Supplies
Amana side-by-side icemaker buttons on door not working properly
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Jan 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Car will not start unless you prim it. I checked the injectors for pulse when I was starting it and got none. However, when I get the car running, I can check for pulse on the injectors and I will be...
I have Found this to be True and To Apply No Start Condision Also IF this Helps YOU Help ME and
And RATE ME Please and Have a Good DAY !!
86ford22
Article No. 86-4-20
STALL - WHILE DRIVING - CFI 5.0L EEC IV(if applies)- LOW FUEL PRESSURE
HESITATION ACCELERATION EEC IV(if applies) - LOW FUEL PRESSURE
FORD 1980-85 CROWN VICTORIA
LINCOLN-MERCURY 1980-85 GRAND MARQUIS, LINCOLN
Poor vehicle performance, (especially during hot weather) may be due to insufficient voltage at the high pressure (in tank) fuel pump. The condition may be corrected by changing the fuel filter and installing a jumper wire to bypass the pump resistor.
1. Locate the fuel pump inertia switch (Sedan: the switch is on the trunk hinge - Station wagon: the switch is at the rear of the vehicle in the passenger compartment).
2. Set a voltmeter, Rotunda Number 014-00407, to read 15 volts or more. Connect the voltmeter between vehicle ground and either side of the inertia switch. (If the vehicle does not run, make sure the inertia switch is not open.)
3. Start and run the vehicle in PARK position and read the voltage.
4. If voltage is below 8.5 volts, change the system fuel filter (located under the vehicle on the vehicle right side just in front of the rear wheel well on a crossmember), and recheck the voltage.
5. If the voltage remains below 8.5 volts, install an overlay wiring harness to increase the voltage above 8.5 volts.
6. Install the overlay wiring harness by attaching the large ring terminal to the battery terminal of the starter relay. Remove the connector from the "I" terminal of the starter relay and insert the male pin of the overlay harness into the connector. Install the female connector from the overlay harness onto the "I" terminal. Tape or install the overlay harness into the existing wiring harness bundle.
7. Start the vehicle, recheck voltage and recheck vehicle for proper operation.
PART NUMBER PART NAME CLASS
E6AZ-9A350-A Wire Fuel Pump Overlay C
OTHER APPLICABLE ARTICLES: None WARRANTY STATUS: Reimbursable within the provisions of the Warranty and Policy Manual. OPERATION: SP9350A86 - Check only. TIME: 0.4 Hr. - Station wagon 0.3 Hr. - Sedan OPERATION: SP9350B86 - Extra time to change filter. TIME: 0.5 Hr. OPERATION: SP9350C86 - Extra time to install harness. TIME: 0.3 Hr. DLR. CODING: Basic Part No. DRIVE - Code: P1, P2, P4
Jan 21, 2009 | 1985 Mercury Grand Marquis
Take power head apart
There's another screw under the sticker. If only one side rotates, it's probably due to a stripped gear. That's what I just discovered on mine...now anybody have any idea where to get a replacement?
Mar 31, 2008 | Office Equipment & Supplies
Carriage jam
There's a small locking mechanism that holds the carriage in it's home position. This needs to be slightly sprayed with WD-40 or a similar lubrication (small amount). Problem solved.
Jan 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Power switch went bad. need to know which pins attach to which wires
Looking at the front of PC remove the left side panel. Now looking in at the board. There are two rows of pins in the lowest right hand corner of the board. Your PWRSW is your power switch. Its a two pin connector. The ground wire will be black or white. The ground faces to the right & connects at pin 4 counting from right to left. Power switch takes up pin 4&5.
All done. If tech switched the wires by mistake than flip the connector 180*.
Jan 01, 2008 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
Asko 24 in. 1805 Built-in Dishwasher Logo
228 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
