Question about Sony RDR-HX715 DVD Recorder
Sony rdr-hx715 says cannot record this picture while trying to record tv. Nothing records, not even commercials. used to work. hooked up to new tv same way. dosent work now. record light goes on. thumbnail appears in title list. blank screen and no audio plays back
  • icemanfred Sep 04, 2010
    Correct input was selected.
    I have used this unit for a few years. so I am familar with it operation.
    Dont know what is going on now.
    I think the key is the mesage "cannot record this picture."
    copyright protection cant be the answer cause nothing records.
  • 666 Answers
If the disc no longer loads on your computer with the data it was suppose to have been written too it may be a finalizing error and you would want to make sure you have all the updated drivers and are using compatible software for it. If after burning the disc it is not being read on other dvd players and is not being read by your own dvd drive on computer or player than it is definitely a hardware problem and will most likely need to be replaced or returned if still under warranty
hope this helps
Robb
Posted on Sep 05, 2010
  • Sony Master
  • 19,396 Answers
Hi.
The DVDR may be tuned on a different input. Ensure that the DVR is tuned on the TV input. Press CH- until you reach input line if the DVR is tuned on TV , otherwise the DVR will try recording from its own antenna input on one of the channels, that probably are not programmed on DVR internal tuner.
Here the manual.
Posted on Sep 04, 2010
Sony KDL 32W705B PLUS A CASSETTE RECORDER RDR-VX 420
Evidently you are recording from the TV. You're running the signal to the TV then out of the TV to the recorder. You should run the signal to the recorder then output to the TV.
May 15, 2015 | Sony Televison & Video
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Sony dvd recorder rdr gx7 sending disc error message
The laser readerwriter is most likely burned out, it is the most common failure. The option of repair is not really feasible as the cost of new is really low.
May 25, 2017 | Sony RDR-GX7 DVD Recorder
Can't get my sony dvd/vcr model rdr-vx560 to record from my tv
I just gave up. I was told this tv didn't have a video input. Just decided to recford on my old vcr and just use the dvd/vcr to dub tapes to dvds. thanks anyway. JoElla
Jan 11, 2009 | Televison & Video
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Failure to record on -R DVDs
DVD-Rs do work with the RDR-VX500 ...... I had not recorded on mine for a few months after I ran out of the last batch ....... then I tried recording on the newer Sony DVD-Rs I had ...... would not record on DVD-R ..... turns out the instructions say the recorder will not work with any DVDs faster than 8x .... It looks like it's recording but it doesn't ..... then I noticed the newer DVDs were 16x ...... found an old 8x and tried it and it works fine ..... turns out the unit won't record slower on a 16x, it just won't record at all ...... get 8x and you'll be ok
Apr 23, 2008 | Sony RDR-VX500 DVD Recorder/VCR
Televison & Video Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
