Question about Dell Latitude D600 Notebook
Cannot connect to wireless internet, have tried FnF2 but this does not work
    Problem Solver:
  • 9 Answers
Have you located and tried disconnecting the wireless card to see if it collected a static charge recently?
It may just need to be dissembled enough to be located and removed for discharging.
Before you do this, try going to control panel in windows, go to device manager, uninstall current driver. Reboot and allow windows to reinstall its compatible driver on startup and see if it restores your wireless connection.
If that doesn't work, before dismantling your laptop to find your wireless card, try to find a tested and reliable wireless card in case you need to replace your current one. That way you aren't wasting your time. After you dismantle your laptop, try discharging your wireless card as stated above, it should be as easy as your memory removal or your modem card removal depending on its location. If discharging doesn't work, replace it with the tested and reliable card. If the new card doesn't work, then you may have a port issue and that may require motherboard work.
There is a cheaper alternative though, purchase a wireless PCMCIA card instead, this will plug into your expansion port on the side. I recommend netgear cards, they have never failed me! This will save you lots of time, money, and stress!
Posted on Sep 15, 2010
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
I can't connect to the wireless Internet despite
Borrow other wireless adaptor, then plug it to your desktop. Try to connect ...but U must install the adaptor driver too. If it works, that means your internal adaptor is out of work.
Jan 01, 2012 | Acer Computers & Internet
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
My asus eee won't connect to the internet via wireless
Contact Asus technical support for getting your wifi problem fixed
Get the best Asus Computer Support by Asus Support
http://asus.techssupport247.com/
Jan 24, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
ASUS N50V FnF2 stopped working.
Dun worry. I experienced that before.. There is a physical wireless slide switch at the right of the indication light. switch it on first and see if it works.
Aug 07, 2009 | ASUS N50Vn Notebook
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Dell Latitude D600 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
