Question about HP LaserJet 1012 Printer
Printing problems I replaced the toner and still get only blank pages printed. Even from printer testing mode (without needing computer). Is it dead?
  • 26 Answers
If you are confirm that your toner is OK then may be your printers scanner shutter is not working otherwise scanner is defected.
Posted on Jun 01, 2008
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Nov 10, 2012 | HP PhotoSmart 7760 InkJet Printer
Hp corol laserjet cp2025 printing blank pages even on printer itself
Mine blank pages where caused by bad black toner, replace with OEM when in doubt.
Oct 01, 2012 | Office Equipment & Supplies
It prints a complete black page, without any images or text. Even at the test page!!!. Any idea as to what can be done?
I think the ribbon or printer head need to be change since it prints a complete black page, if it is a blank page it prints, i would have said the toner ink is low in the cartridge or finished but since it is a black page it needs replacement.
I suggest you get a technician to help fix it.
I wish you best of luck
Dec 22, 2009 | Samsung CLX2160 Multifunction Color Laser...
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Sep 12, 2008 | Kyocera FS-4000DN Laser Printer
Blank papers
Try again the old toner cartridge if you still have it. Even though the print quality might be bad, see if there is a printout. If the page is not blank like the others, that is an indication that the new cartridge is defective and has to be replaced.
Sep 05, 2007 | HP LaserJet 2420 Printer
Printing problems
Hi, There are 3 things that can cause blank pages. The most common is the laser shutter pops off on the spring side and blocks the laser from hitting the cartridge. The shutter opens when the cartridge is inserted. The cartridge guide that sits above and behind the cartridge misteriously gets eaten by the printer. Without it, the cartridge rides too high for the toner to transfer. The high voltage power supply goes totally dead. If the first 2 are ok, then replace the high voltage power supply. (There are 2 power supplies in the printer. One the low voltage power supply supplies voltage to all the boards, fans, etc. The high voltage ps only supplies voltage to the toner cartridge.)PS-The laser/scanner shutter is found under the top cover and below and by the front of the laser/scanner assembly (black box). Control of the shutter is on the left side of the laser/scanner. Good luck
Sep 03, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 1012 Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
