Question about Philips GOGEAR SA6045 MP3 Player
My power doesn't come on,when i connect it to my pc,i see a blank battery and the inscribtion ok to disconnect
    Problem Solver:
  • 5 Answers
There is driver problem with your PC. you just have to install latest windows media player. If the problem still exist change the data cable.
Posted on Sep 04, 2010
Blank screen
Remove the residual power from the computer and check if it works.
To remove residual power, disconnect the power cable and battery from the computer. Press and hold the power button down for 20 seconds. Connect only power cable to the computer and check if it boots
Aug 20, 2014 | Gateway Computers & Internet
My Phillips MP3 Player hangs
Philips SA30XX MODEL GO GEAR NOT DISCONNECT AND NOT WORKING NOW ONLY SO OK TO DISCONNECT
May 16, 2013 | Philips GOGEAR SA6045 MP3 Player
Fatal Error:
It sounds like the port not the battery. You should take it someone to repair it. They are not expensive...
Dec 15, 2011 | Dell Inspiron Mini 10 Notebook
Cant connect gts3310 metro to net through pc os window xp tried all possible ways prtocol terminated appears when conected by pc suit
Run pc suit and add ur mobile device
Go to internet connector and add a network connection settings
Set name; TATA DOCOMO INTERNET
Country; india
Isp provider; TATA
Apn; TATA.DOCOMO.INTERNET
USERNAME; BLANK
PASSWORD; BLANK
OK
THEN CONNECT WITH IT . mobile gets automatically disconnect and then connected with a long msg error.
Then close the pc suit
Now open control panel
Go to network connection in xp
Go to properties of TATA DOCOMO INTERNET
CHANGE the phone number from #777 to *99***1#
Then ok and connect.
Oct 16, 2010 | Cell Phones
My computer will not start, when I turn the computer on it has a blank screen. How can I fix my computer?
try to go BIOS AND CHECK THE DISPLAY,IF THE DISPLAY IS OK THEN TRY BELOW
1.check the power connection of the computer
2.check the power connection for monitor or any loose connection.
still nothing is coming do the next.
turnoff the computer completely,disconnect the powercabel,disconnect all the external devices press and hold down the power switch on the tower for 30 seconds,reconnect the power restart the computer.
Sep 16, 2010 | Computers & Internet
Ok when I turn on my laptop it boots up and starts working but after I sign in my screen goes blank (black) so I hooked up monitor and I can see the video card is working.. Now the funny thing is if I let...
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 20, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
Wont switch on
Suggest disconnect from AC power, and remove battery. Push power button 10 times, depressing for 2 seconds each time. This will flush the capacitors.
Then, reconnect AC power and press power button.
Try that. Does it work? If so, you might have a power problem on your motherboard. This is a work around, as repairs can be costly, time consuming, and more of a hassle than their worth.
-Jon
Sep 25, 2009 | Gateway Computers & Internet
Screen goes blank when on battery power
Two possibilities: The display is a power hog. It's possible that the battery is failing, and has enough power to run the PC, but not the PC AND display at the same time. You would need to replace the battery, in this case. Or, in Control Panel, in Performance and Maintenance, in Power Options, there should be settings somewhere for the display when on battery or AC power. Make sure that the one for Battery doesn';t turn the display off after 0 minutes.
Mar 03, 2009 | Dell Inspiron 1521 Laptop
My Mobile has a Powering problem and it doesn`t work because it was connected to my PC via USB and disconnected suddenly
contact nokia or a local phone shop to find out where to get it repaired.
www.nokia.com
You can try removeing the battery for 30minutes and trying again.
Jul 26, 2008 | Nokia N73 Cellular Phone
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
