Question about Canon iR 2016i Black and White Copier
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what could be the problem and how can it be solved? this machine showed that massage after being taken to the technician. i have tried to set all the settings to default, cleaning the drum, removing the residues in the drum,
  • 1,219 Answers
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Posted on Sep 04, 2010
Canon copier error e000007-0000 canon 2420 image burner
Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Mar 10, 2015 | Canon Office Equipment & Supplies
How do I restart the massager after it overheats?
As far as I know (from my experiences with my 10-year-old model), all that is required is to allow the unit to cool off before attempting to restart.
Perhaps the company has updated the electronics with addition of a thermistor. If so, it would require replacement (but I doubt this to be so)
Sep 10, 2014 | Thumper Mini Pro 2 Massager
RECORDING AND LISTENING GREETING MASSAGES
The manual indicates where you may need to reset the unit if the memory is full or even if you just want to clear it, page 89-90.
You may use code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Mar 05, 2014 | Panasonic KX-FM220 Plain Paper Thermal Fax
I have really bad lower back pain. Is there a way I could learn to use massage oils to relieve the pain?
Massage oils can play a big role in helping with muscle pain and joint problems. I would suggest that you watch this YouTube video for a really detailed instruction about how to give a massage to reduce lower back pain. Obviously it's a bit hard to do on yourself, so you may need to recruit someone to learn with you.
http://www.videojug.com/film/how-to-massage-away-lower-back-pain
Mar 04, 2013 | Health & Beauty
Mistakenly we kept the homedics massage system in 230v instead of 120v voltage. It's not working now. Is there a way to fix it.
if your Homedics Back Massagers has a product warranty you should bring where you buy it..
if has to warranty you can try some techie sollution.
if it has an adaptor that connected to massagers you can change it with the same specs.
most adaptor has a label that indicates volts amphere and connector polarity..you can buy same specs at ebay.. or search some electronic store.
if it has no adaptor you have to dismantle your massager and search the fuse or circuit connected to
the ac line.. good luck....
Aug 21, 2011 | Homedics Health & Beauty
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
May 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Massage storage memory not ready
Try restarting you mobile couple of times.Revert back.
Jun 09, 2009 | Nokia 2626 Mobile Phone
It just said sim lock. How do i get the sim lock off
step 1.
Switch off your moblie
Remove the Sim and switch on the mobile at this stage mobile show the massage"Insert the SIM"
Enter this code
*2767*3855# let it reboot(restart)
now its ready for permanent.
step 2.
now put this code
*7465625*638*00000000*00000000# (I
will show in the screen like this-------- for
00000000)
NEXT ENTER
#7465625*638*00000000#
Now its Permanent Unlock ....
Jun 05, 2009 | O2 Samsung SGH-E250 Cellular Phone
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Canon iR 2016i Black and White Copier Logo
55 people viewed this question
old marine
old marine
