Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook start-up my macbook is starting up but its not loading. it just has that apple and the loading circle under it, and that is all it does. can someone pls help?
  • 3 more comments
  • JEFFANTH May 19, 2008
    WHEN I TURN THE COMPUTER ON IT DOESN'T LOAD TO DESKTOP, I JUST SEE THE APPLE WITH A CIRCLE TURNING UNDER NEATH
  • johngonjr08 Aug 06, 2008
    mac lights up but does not load
    does not load desktop
  • Anonymous Aug 07, 2008
    starts to load with apple symbol, the symbol goes away but gray screen remains and then after a few minutes it turns it's self off.
  • Anonymous Dec 12, 2008
    Hi you guys. I am going Nuckin' Futs. I just got this macbooc through ebay. I got it on fine. Then I updated some programs and restarted. Now It wont do anything after you turn it on and the apple logo and spinning circle. It goes on non stop. The computer came by itself with no CD's or Nothing. Can someone help?
My macbook is starting up it just that apple and the loading circl under it and then a blue screen pop up with a arrow but the screen wont show nothing and i could move the arrow
Posted on Jan 31, 2009
We'll that happened to me also.. i researched and found if you goto apple.com and look up support for macbook. Look for .pdf macbook repair manuel. There you'll get start up procedures. turn off power. Then load start disk, hold down "alt/opt" button and then turn power on. Wait for a min or two and then you'll see your hard drive and start disk to choose from. Choose start disk and click enter. Be sure your disk isn't scratched.. i had that problem. Then wait... it takes awhile so be patient. You'll get the whole set up again. DONT ERASE YOUR PRIOR DISK!!! Thats where i screwed up! So.... you should be able to get what you want .. if not.. its a new hard drive you'll need to buy... i'm heading to Best Buy and the Geek Squad for my help!
good luck!
Posted on Jun 01, 2008
    Problem Solver:
  • 14 Answers
Most cases you only need to re-install the operating system.
try unscrewing the ram door in the battery compartment(will not void apple warranty) pull the tab to remove the hard drive then re-insert it,then piece back together.and power up to see if it is the same prob upon booting(that rules out a bad drive)if prob stays follow the steps to re-install the operating system
Posted on Aug 10, 2008
  • 4 Answers
Http://www.retrodata.co.uk/notice_apple_seagate_drives.php
Posted on May 15, 2008
My MacBook Pro is stuck on the grey start up screen with the apple logo and a spinning circle. Sometimes it gets to a probationary circle with the spinning circle.
Unfortunately, this sounds like a problem with your hard drive/ logic board. To Fix This You Will Need To Go To The Apple Store And They Will Most Likely Have To Replace Or Repair It. the Process Takes About 2 Days - 1 Week (Just To Set Expectations.) :(
Aug 28, 2012 | Apple MacBook Pro Notebook
I bought Macbook air 11"
This exact same thing happened to me, the only way I got my laptop to work again was to reinstall the laptop's original operating system software. Follow the instructions on this website:
http://www.ehow.com/how_4894762_reset-apple-mac-book.html
By doing this your macbook should work again, but all information on your harddrive will be erased including non-standard applications such as word ect...
May 07, 2011 | Apple MacBook Air
I have a mac air and I am having volume problem. When I attempt to adjust the volume I get a circle with a line over it. Also I can no longer watch video since this problem occur. The video would load play...
The problem is that the headphone jack for you Macbook Air is a copy Analog (standard headphones) and Optical (toslink) jack. The jack has a small microswitch that detects when the cable inserted into the jack is a metal analog connector or a fiber optic toslink cable. The reason your seeing the "NOT ALLOWED" sign (circle with a slash through it) is because you cannot not adjust the volume on the sound when the output is in DIGITAL MODE. To verify this, drop down the jack cover on the side of your macbook air and place your index directly in-front of the headphone jack about 1/2" away from it. Is you finger glowing red? That's because the fiber optic LED is turned on and Mac OS X thinks that there is a toslink cable inserted into the jack.
This is a known hardware problem with that type of combo-jack and affects a lot of other Macbooks, as well.
If your Macbook Air is still covered by Apple Care, take it into an Apple store and have them replace the jack. I know this is a pain, but it is the correct answer.
If your Macbook Air is NO LONGER UNDER WARRANTY, you can attempt to fix this yourself, but be warned, you could break stuff!
Here is a thread at the Apple support forums discussing this issue: http://discussions.apple.com/thread.jspa?messageID=3255575
The above link is good background reading and will help you understand the issue further. The short answer is that many people have inserted a toothpick (other similarly sized NON METAL object) into the headphone jack, wiggled around until the microswitch is clicked off, then normal audio resumes. My 2009 Macbook Pro 17" has the same issue, but I have found that I can take a regular pair of headphones, insert the jack, wiggle it, remove it, reinsert, remove it....and repeat this process until the switch gets toggled. It's annoying, but I have to do this until I get home and can send it back to Apple for warranty work.
May 21, 2010 | Apple MacBook Air
My apple notebook will not connect to the network
your software probably corrupted.Reinstall the software and checj
Apr 08, 2010 | Apple MacBook Mac Notebook
Macbook Startup Never ending Apple Logo and Circle
try holding down the alt(option) key when starting up it should give you a list of startup options, it sounds like you dont have a astartup disk (an operating system) installed.
Dec 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
MacBook Desktop Lost My Desktop Folders
If the colour circle shows... find a tiny bit of wallpaper showing through the back, then click. Then, you should see it labled finder instead of preview. Next, click on the blue apple. If it doesn't happen immediatly, a dropdown bar will show in a couple minutes. In the dropout bar, click Force Quit. It usually takes 2 minutes for the Force Quit window to show up. It'll ask you what you want to force quit,  Look at the choices and force quit all of the ones that say: NOT RESPONDING. Then the computer will clear up for a while, in wich you can probably preview your pictures.
Aug 12, 2008 | Apple Power Mac G4 Dual Mac Desktop
Mac notebook problem
It sounds like youre hard drive may be failing. Power it down and when you turn it on next, hold down the OPTION key ( should send you to start up manager ) right after you hit the power key. What do you see?
Jul 09, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
615 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
