My hp compact presario will no boot it is saying boot failure insert disk error message is on black screen and I cannot find my system disk
    Problem Solver:
  • 16 Answers
Did you check to make sure you don't have any discs, cd's or floppy discs in the pc when you turn the machine on?
Posted on May 11, 2008
Compaq screen comes on, then goes to black screen with "disk boot failure, insert system disk and press enter" I don't have a sytem disk, where can I get one?
This would depend on which OS you are trying to install. Also, if the system booted before and you are receiving this message you probably have a bad hard drive or corrupted system files. There are free operating systems out there such as Unix and Linux, or you can go through Microsoft and get the OEM disc for your preferred operating system. If you do not want to puchase the OEM disc yourself then you can also go through a pc repair shop and have them do an OS reinstall. Hope this helps, let me know if I can assist you with anything else.
Apr 10, 2011 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
Hello. . . I have a 2006 HP desk top computer with Vista and the entire screen is black w/message saying Boot Failure, insert system disk. Also previously I recvd an err1err3 message. I've already spent...
Boot failure message is shown because you have uninstalled any important drivers,deleted any system files or it is a virus infection problem. You need to recover your windows from windows vista DVD. Check it to your dealer.
Jul 14, 2010 | HP Computers & Internet
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
System error
Sounds like your hard drive maybe had it. Try to do a repair with your windows disc.
Mar 17, 2009 | HP Compaq Presario SR2011WM PC Desktop
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
