Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Remote control stopped working
I purchased a Philips 37PF7320A 37 in in Dec. 2006 and worked fine until this weekend. The remote no longer works. Both the remote that came with the TV as well as the remote that came with cable which was working fine. Batteries are fresh in both. At first the TV wouldn't turn on/off with the remotes, then the volume control stopped working, then all the rest of the controls. I can still operate the TV from the controls on the side. Warranty expired 5 months ago.
Any idea what's wrong? Thanks in advance for your help.
  • 1 more comment
  • buckskinbowm May 11, 2008
    Could you elaborate a little more on what exactly the SAA7130 TV Card Driver is?? I did download a firmware upgrade for the TV, but that didn't help the problem with the remote no longer working.
    Thanks.
  • Martin000 May 28, 2008
    I have exactly the same problem. Got home this evening to find that neither the TV remote nor the cable remote can power on the tv or change volume. The controls on the side of the tv set work fine. First thing I did was replace the batteries in both remotes, but no luck.
  • buckskinbowm Jul 23, 2008
    Well, just a little over two months after reporting the problem with the remote control not working, now I get the dreaded "flashing red light". I should have known that the remote control not working was a symptom of a much bigger problem about to happen.
    I called Philips customer service and was told that the nearest service center was located about 70 miles from my house, and I live in a major metropolitan area! What have other people done when they encountered this problem? Based upon other Google results I've done, it sounds like this is a very expensive problem to fix.
    Thanks for any advice.
Hey. I paid the $20 for the expert advice and (I feel such a fool) I just had to unplug the tv and plug it in again for everything to work!
Martin000
Posted on May 28, 2008
Download SAA7130 TV Card Driver
Posted on May 11, 2008
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Small green line on right side of screen
This is an easy fix using the Philips remote control that came with your tv. On the center of the remote is a dial that has left right up down controls. Stand in front of the tv and using those controls you can recenter the screen and get rid fo the green line. I had same problem when we hooked up hd satellite reciver to philips 37 plasma
Feb 18, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My remote for the Philips DVDR 3455 stopped working. What can I do?
hello. Begin by replacing the batteries in your remote. If that does not make a difference go to any walmart or radio shack and purchase a universal remote control.
Jan 09, 2010 | Philips DVDR3455/37 DVD Recorder/HDD...
Not connection between tv and remote control
try this take the battery out push every button for devices then put the battery back in and see if that works.
Mar 23, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Problems with your Philips 37PF7320A 37 in remote control
If the remote has been replaced the IR receiver could be bad. Try changing the channels with by the tv. Most likely that is the problem.Beside that the small signal board could be an issue. But I would the IR receiver would be first.
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Mar 02, 2008 | Big Button TV Universal Remote
Philips 37PF7320A 37 will not turn on
moswt of these i have come accross is either an SSB(small signal board) or a logic board. in rear cases it even requires the replacement of the panel unfortunety ther are a number of test that need to be done on the unit to figure which one it is and i dont recomend you try them yourself.
Jan 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7321D LCD TV
Try to replace the power supply board of your tv.
Nov 15, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV doesn't recognize any remote
The proble is the IR sensor 932220681667 or the small signal board. I would replace the IR sensor first. Also check the firmware and make sure it is BX23U-1.5.0.0_03531 and if it is not go to www.usasupport.com and down load the firware on a USB stick. If the set still has the problem when both are done replace the small signal board.
Jun 17, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
237 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
