Question about Compaq Presario 700 470024-192 Notebook
Delayed response to keyboard entry
Any tap on keyboard responds after 1-2 secs! Unable to get solution anywhere!?!
Tengo problemas para encontrar el los drivers de la compaq presario 700 la para windows 98
Posted on May 14, 2008
Number lock key
1. Please tap the NumLock key many times and see if it responds to the tap,
2. Probably your keyboard is in "Alt Fn" mode, so please try to hold the Fn key and tap the Fn key (I prefer to tap the left arrow and right arrow) and see if the keyboard is working properly.
3. Probably your keyboard is failed. It happens, even there is no spill accident. In this case, you need to replace the entire keyboard.
Dec 25, 2013 | Computers & Internet
Keyboard input delayed I have to hold keys for down for 5 seconds 4 data entry
Open control panel and the open KEYBOARD. Now you can set the level of timing which can be presetted to your requement.
Check on the links and test the keyboard. If not there are errors in the keypad or the drivers/OS.
Aug 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
Keyboard keys have a delayed response
It must be an USB keyboard...try changing the the keyboard connection to some other USB slot
this will end your problem friend, because in usb slots there are both faster and slower slots
"be free to ask further doubts friend...am here to help u based on computers:-)"
Jul 19, 2011 | Compaq Keyboard
The touchscreen on my Samsung Impression SGH-A877 does not work at all. Started about a week ago when I noticed that it was not selecting the things I touched on the screen, but selecting the entry above...
Hi,you will have to replace the flex of the phone.
The flex make the touch pad to function,also the functioning of the number keys.
When you replace the flex the touch pad and the key will function again.
Thanks for using fixya.
Oct 01, 2010 | Samsung SGH-A877 Impression Cell Phone
Keyboard not responding.
Your problem sounds more like the system running slow rather than the keyboard being the issue.
Do routine maintenance and cleanup on your system to see if it helps it.
To start the Disk Cleanup tool and specify the hard disk to clean by using a command line, use the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the following line and then press ENTER
    cleanmgr
  3. click OK
  4. The dialog box that opens shows you the files it will remove to clean up the system
  5. Make sure Temporary files is checked
  6. Click OK
Then check your system for malicious software.
  1. Go to http://malwarebytes.org
  2. Download and scan the system
  3. Remove all found infections.
  4. Restart your system
These things should help if this is the cause.
If your problem still is present, change the battery in the keyboard. A battery that is close to empty will cause this as well.
Let me know if this resolves your issue.
May 15, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
This post seems to be a duplicate of one posted under the name of Guest, so, I am pasting the solution here just in case you have not gotten notification of resolution suggestions.
    cleanmgr
  3. click OK
  6. Click OK
Mar 26, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
My palm Vx asks me to tap center of target but doesn't respond
If there is no response anywhere at any time then you probably have to replace the digitizer. Also if you have a plastic protector sheet take that off and try it.
Mar 01, 2010 | Palm Vx Handheld
Delayed response for keys
go into your control panel (classic view if you are using vista)... click on the keyboard icon... you can change the delay rate there
Robert
Please take a moment to rate this solution... thanks
May 22, 2009 | Dell Inspiron 1501 Notebook
Delayed and unressponsive keyboard
the keyboard may just need servicing so take the phone and have that done at a repair shop/
Dec 14, 2008 | LG RUMOR Cellular Phone
Delayed keyboard response on Dell Inspiron E1705 Laptop
Is the mouse response sluggish as well during these times?
In most cases, it means the computer is busy with another process. The keys you press stay in the keyboard buffer until the CPU has time to process them.
Check your CPU busy time when this happens. In Windows XP, press ctl-alt-del to start the task manager, the select the processes tab to see if one process is tying up the system (by % of CPU), or press the performance tab to see CPU usage. If it is pegged at close to 100%, something is tying up the system.
May 12, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
