The term seven sisters is used for 1.hindugoddesses 2.northeastern states 3.southern rivers 4.northern mountain ranges
aborcass
  • 2651 Answers
SOURCE: gas pipe manifold pipe size is 3/4 " , should be 1/2 "
find it comicall that the last 3 suggestions all though im sure they wanted to help , not an appliance background on any of them.GOOD SHOW!! you state you just recieved this unit??? did you buy it from a dealer new, or aquire it second hand from another source?? without seeing it for myself im takin you word that its sized incorrctly. did you try calling the manufacture ( they would know their product better then anyone and if there is a discrpency they will be able offer you a solution)definatly should not be relocating or unhooking cooling fans to install the unit. 1-800-735-4328
1-800-656-9226
i did download an installation manual, didnt have your model but checked a few and seemed to be the same. asking that you install the supplied pressure regulator, perhaps you didnt install that and thats where the pipe sizing diff is.
Posted on Oct 23, 2008
  • 112 Answers
SOURCE: Vulcan Range that wasn't heating.
The half inch tubing should be adequate under most circumstances. However, you may run into volume issues while using the oven and a few burners at the same time. If it bothers you, replace it. The door should be flush (or close to it) on the sides and the top. If you have an air gap, check the hinges.
Posted on Nov 10, 2008
  • 179 Answers
SOURCE: I have to put the plug wires back on the distributor.
okay remove your driverside sparkplug the one closes to the front this should be #1 piston put a screw driver in the hole but dont let it bind, slowly click the starter until the srew driver come up all the way up this is top dead center TDC now look at the rotor and where the cap lines up this #1 second is#8 piston on the pass side closes to the fire wall or cab so, on the engine #1 piston234 onthe driver side 5678 on the pass side and in order on the cap it should be 1 8 4 3 6 5 7 2 also make sure you didnt drop the dist in wrong and hav it 180 degrees backwards dont get frustated stop and try again later also make sure this is the right firing order for your dodge i gave you a chevy fire order but i am almost positve this is the order for all v8s
Posted on Jun 02, 2009
appman67
  • 33 Answers
SOURCE: possible impulities in irrigation water
There are so many variables to answer this that more specific information is required. 1. Depends on both mineral deposits in the affected area and nearby industry that may cause pollution. 2 & 3. Depends on terrain, objectives and application. 4. Depends on type of plants desired and their tollerances to existing soil conditions. Also, economics of soil modification.
Posted on May 16, 2010
SOURCE: Mountaineer idles at 1 1/2 when you start it. When
Hello. Please check your Coolant Temperature Sensor. It tell the PCM what the engine temperature is so that I can adjust the injectors and Air/fuel mixture. If it can't get an accurate temperature it goes to the default level. When you first start the engine it is cold, and the adjustment is good, but when it gets warmer the air molicules are farther apart, this means when warm, air is thinner. Thinner air getting the same amount of fuel means that the air/fule mixture is going to be "richer." or more gas per fuel. That is why your Mountaineer idles higher, same amount of gas, thinner (less) air.. I hope this helps you understand what happens in this system, and why I believe that this amy be your trouble. Thank you for trusting FixYa.com to help get you going! Please rate the solution by your experience, Thank you.
Posted on Jun 28, 2010
Local SA Phone Numbers
00: International access code effective from 16 October 2006 and mandatory from 16 January 2007.
01: The old Transvaal province, currently comprising Gauteng, Mpumalanga, Limpopo and part of the North West:
010: New overlay plan for Johannesburg011: Witwatersrand region around Johannesburg, currently code for entire Greater Johannesburg012: Pretoria and surrounding towns (also includes Brits)013: Eastern Gauteng (Bronkhorstspruit) and Western and northern Mpumalanga: Middelburg, Witbank and Nelspruit014: Northern North West and Southwestern Limpopo: Rustenburg and Modimolle015: Northern and Eastern Limpopo: Polokwane016: Vaal Triangle: Vereeniging, Vanderbijlpark and Sasolburg, which constitutes an anomaly, since Sasolburg isn't the old Transvaal.017: Southern Mpumalanga: Ermelo018: Southern North West: Lichtenburg, Potchefstroom and Klerksdorp 02: Western and Northern Cape:
021: Cape Town metropole and surrounds, including Stellenbosch, Somerset West and Gordon's Bay022: Boland and West Coast: Malmesbury023: Worcester and greater Karoo, including Beaufort West024: Somerset West (Became 021 in 1996)027: Namaqualand (Northern Cape): Vredendal, Calvinia, Clanwilliam, Springbok, Alexander Bay, Port Nolloth028: Southern region: Swellendam and Caledon / Hermanus region. 03: KwaZulu-Natal:
031: Durban032: KZN North coast region: Verulam, Tongaat, Ballito and Stanger033: Pietermaritzburg and KwaZulu-Natal Midlands034: Vryheid, Newcastle and Northern KZN035: Zululand region: St. Lucia, Richards Bay, Ulundi036: Drakensberg region: Ladysmith039: South coast: Port Shepstone and interior, and Eastern Pondoland (in Eastern Cape) 04: Eastern Cape and eastern parts of the Western Cape:
040: Bhisho041: Port Elizabeth and Uitenhage042: Southern region: Humansdorp043: East London and surrounds044: Garden Route, including Oudtshoorn, Knysna, Plettenberg Bay, Mossel Bay and George045: Central region: Queenstown046: Southern region: Grahamstown, Bathurst, Port Alfred, Kenton-on-Sea047: Mthatha / most of previous Transkei048: Northern region: Steynsburg049: Western region: Graaff-Reinet 05: Free State and Northern Cape
051: Central and southern region: Bloemfontein, and Aliwal North in E Cape053: Kimberley, eastern part of Northern Cape, far west of NW province054: Upington, Gordonia region056: Northern Free State: Kroonstad057: Northern Free State: Welkom (Goldfields region)058: Eastern Free State: Bethlehem 06: Mostly unused, partially allocated for Cellular use.
0603 - 0605: Cellular: Used by MTN0606 - 0609: Cellular: Used by Vodacom0610 - 0613: Cellular: Used by Cell C0614: Cellular: Used by 8ta (Telkom)0615: Cellular: Used by Cell C0618 - 0624: Cellular: Used by Cell C062: Cellular: Used by Vodacom063: Cellular: Used by MTN064: Cellular: Used by Cell CCellular: Used by Cell C 07: Cellular
0710: MTN (spill-over from 083)0711 - 0716: Vodacom (spill-over from 082)0717 - 0719: MTN (spill-over from 083)072: Vodacom (spill-over from 082)073: MTN (spill-over from 083)074: Cell C (Cell C has allocated 0741 to Virgin Mobile)0741: Virgin Mobile as of June 2006 [6]076: Vodacom (spill-over from 082)078: MTN (spill-over from 083)079: Vodacom (spill-over from 082) 08: Special services
080: FreeCall, Toll-free, called party pays0810: Cellular: MTN0811 - 0815: Telkom Mobile (8ta)0816: WBS Mobile (should be noted that Vodacom and MTN both have terminated SMS interconnect with WBS so SMS messages to/from this number range are /dev/null'ed)0817: Telkom Mobile (8ta)0818: Cellular: Vodacom082: Cellular: Vodacom083: Cellular: MTN083-9 Cellular rates to Telkom lines, reroutes call to a telkom line and pays number owner for received calls084: Cellular: Cell C085: Cellular: USAL license holders - Vodacom and MTN have some prefixes out of this range for their USAL offerings086: Sharecall, MaxiCall and premium-rate services, calls can be routed to regional offices automatically0860: Sharecall Land line callers pay local call, called party pays long distance if applicable0861: MaxiCall caller always pay long distance for call even if routed to local office0862 - 9: Premium rate caller pays increasing rate linked to last digit[7]0862, 0865, 0866, 08673, 08774, 08676: Fax to Email caller always pay increasing rate linked to last digits08622, 086294: Competition lines caller always pay premium rate08671 - 08674: Information services caller always pay increasing rate linked to last digit087: Value-added services (VoIP [1] among others)088: Pagers and Telkom CallAnswer voicemail089: Maxinet, for polls and radio call-in services Note that since 10 November 2006, mobile number portability was introduced in the cellular market. The cellular prefixes as above are therefore not strictly applicable anymore although they remain mostly unchanged.
09: Old international access code no longer in use.
There are still some non-automated exchanges which use longer dialing codes, mostly for 'Farm Lines' and remote areas with operator assisted exchanges.
Mar 17, 2017 | Cell Phones
Where do zebras live
Though they all live in Africa, each species of zebra has its own home area. Plains zebras live in the treeless grasslands and woodlands of eastern and southern Africa. The Grevy's zebra lives in in the arid grasslands of Ethiopia and northern Kenya. The mountain zebra is found in South Africa, Namibia and Angola.
Feb 23, 2015 | Office Equipment & Supplies
Where is the Red River? In Texas
the Red River is the second-largest river basin in the southern Great Plains.[4] It rises in two branches (forks) in the Texas Panhandle and flows east, where it acts as the border between the states of Texas and Oklahoma. It forms a short border between Texas and Arkansas before entering Arkansas, turning south near Fulton, Arkansas and flowing into Louisiana, where it flows into the Atchafalaya River. The total length of the river is 1,360 miles (2,190 km), with a mean flow of over 57,000 cubic feet per second (1,600 m3/s) at the mouth.
Aug 30, 2014 | Genealogy Family History Texas Land Survey...
Types of snakes with pictures
The eastern ribbon snake or common ribbon snake (Thamnophis sauritus sauritus) is a subspecies of ribbon snake found in the northeastern United States.
Some similar species are the western ribbon snake, common garter snake, Plains garter snake, and Butler's garter snake.[2]
The other subspecies are the northern (T. s. septentrionalis), Peninsula (T. s. sackenii), and bluestripe (T. s. nitae) ribbon snakes.
Eastern Ribbon Snake
Aug 27, 2014 | Home
Use 10-W 30 or 40 oil in my ...
In southern states, 10-40
In northern states or winter, 10-30
Aug 14, 2014 | 1997 Buick LeSabre
Creedence clearwater revival rock band history
Creedence Clearwater Revival-occasionally shortened to Creedence or CCR-was an American rock band popular in the late 1960s and early 1970s.
The band consisted of lead vocalist, lead guitarist, and primary songwriter John Fogerty, rhythm guitarist Tom Fogerty (John's brother), bassist Stu Cook, and drummer Doug Clifford. Their musical style encompassed the roots rock and swamp rock genres. Despite their San Francisco Bay Area origins, they portrayed a Southern rock style, singing about bayous, catfish, the Mississippi River, and other popular elements of Southern iconography.
Creedence Clearwater Revival's music is still a staple of American and worldwide radio airplay;[1] the band has sold 26 million albums in the United States alone.[2] Creedence Clearwater Revival was inducted into the Rock and Roll Hall of Fame in 1993.[3] Rolling Stone ranked the band 82nd on its list of the 100 greatest artists of all time.[4] Their musical influence can be heard in many genres including southern rock, grunge, roots rock, and blues
Jun 03, 2014 | Measuring Tools & Sensors
What weight oil should be used in 1987 goldwing
You don't mention where you are located so I'll have to assume you are in North America. Generally use 10/40 in Canada or the northern states, 20/50 in the southern states.
Jun 02, 2014 | 1987 Honda GL 1200 Aspencade Gold Wing
Question Investigate the relationship between the
This is not the kind of material for this site, we are a self help repair and use site for manufactured products.
Mar 01, 2017 | Office Equipment & Supplies
Help with Curious Village game on Nintendo DS
Hi Gill
For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
Hope this helps and good luck!
Scott
Mar 25, 2010 | Nintendo DS Console
188 people viewed this question
k24674
