Question about Gateway HD1900 19" Monitor
What is the most likely cause of the problem of a gateway HD1900 monitor fine works for 5 minutes when powered on then goes dark but imagine can be seen in background
  • Gateway Master
  • 11,800 Answers
The back lighting fails - the CCFL tubes lose their power most likely because of a bad contact.Open the case of the monitor and press all wires firmly in their connectors.
Posted on Sep 04, 2010
What connections are required
Make sure the monitor works on a friend's PC using the DVI... let's not go backward to VGA when DVI is available on both the PC and monitor. If the monitor works, install the driver and reboot. It should work for you too.
Jun 19, 2014 | Gateway HD1900 19" Monitor
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
Display comes on, says "Digital," then goes black.
I'm not sure what's happening, but here are some questions to ask yourself:
-Are all the cables properly connected? Monitor to computer, monitor to wall?
-Is your graphics card properly inserted in your computer?
-Does the display work when plugged into a different computer?
-Is the computer plugged in and turned on?
There's a troubleshooting section in the user's manual, found here:
http://support.gateway.com/s/Manuals/Monitors/8513019.pdf
Mar 07, 2011 | Gateway HD1900 19" Monitor
Gateway monitor FPD2275W TFT LCD powers on, gateway logo goes on fine with brightness then monitor brightness drops so you can barely see it. Not sure if this is a problem with the brightness setting or...
The back lamps that provide the illumination of the
colors, is shutting down there are feedback circuits when there is a problem
with the lamps it will shut down the lamps. Replacing the lamps should alleviate
this problem. For more information on this email me at Sprint6@zoominternet.net
Dec 22, 2010 | Gateway FPD2275W LCD Monitor
Looking for the gateway hd1900 lp1925 drivers, any ideas?
No ideas here, but if you find/found them please link. Thanks!
Oct 09, 2010 | Gateway HD1900 19" Monitor
The power button keeps blinking every 2-3 seconds and the screen is black and wont turn on
It sounds like it is in "sleep mode"
Try pressing any key on the keyboard and see if it wakes up.
Nov 04, 2009 | Gateway HD1900 19" Monitor
Monitor not powering up. Theft deterrent?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 18, 2009 | Gateway HD1900 19" Monitor
Monitor on a 400 vtx gateway
Check the output voltage of the invertor board , if its 150 volt (point of cold fusion lamp connection) then the drive electronics of the invertor board from the motherboard is damaging the new invertor boards which you are trying to replace. Check input to the invertor board it should be 5 Volts and 12 volts .
Apr 29, 2008 | Computers & Internet
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Gateway HD1900 19" Monitor Logo
446 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
