Motherboard Manual I am looking for a motherboard manual, the board is a SiS 730 BN730E Ultra, I have unpluged the front USB socket plugs and not relizing they where separat plugs and not one big block they have split on me and now I dont know witch plug goes onto what pin on the board. Can you help Alan Simmons
  • 981 Answers
How many different ways can they possibly go? Persist a little! It's safe to just plug them in and see which way the system starts.
Safer in fact than wasting time digging up the disc! Sorry.
If you want the manual or have thought of a way to hunt down the documentation authors and present them bouquets of gladiolus, you could of course google a bit and come up pretty blank (unless you hit on ECS's purchase of SiS, or browse EETimes for industry news) or be faced with the age and performance/watt of that system at http://www.anandtech.com/printarticle.aspx?i=1381
Posted on May 11, 2008
How can i plug the frunt pannle audio jeck
Look into the motherboard manual there is usually a scheme where says every pin connector for usb or jack or whatever, or take a look into the motherboard and it could say something like JS_AUDIO1 near the JS_USB1, but take a closer look into the manual.
Jan 10, 2012 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Where can I find the drive r to K7S746FX ?
HI..................
Part Number K7S746FX Manufacturer Legend QDI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset SiS 746FX North Bridge SiS 746FX Socket Socket A (462) Processor Types Athlon, Duron Number of CPUs 1 Front Side Bus 333/266/200MHz Memory Type DDR, SDRAM Memory Channels Single Maximum Memory 3GB External Graphics AGP8X IGP None South Bridge SiS 963L Audio 6-channel IDE 133/100/66/33 SCSI None SATA None RAID None LAN 10/100 Firewire None USB USB 2.0 Expansion Slots
BIOS
Form Factor ATX
THE LINK IS GIVEN BELOW.............
http://www.motherboards.org/mobot/drivers/Legend%20QDI/K7S746FX/
Sep 23, 2011 | QDI Group QDI KinetiZ 7T Motherboard
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
SWITHCHING MOTHERBOARDS
There will be writing on the motherboard in several places, look very carefully and then google
Everything should just plug in without a problem, each device (ide cable/sata cable/CPU/graphics card) uses different shaped plugs and sockets, they can only usually plug in there own sockets.
Unless you are going to a newer technology ( IDE to SATA or AGP to PCI-E graphics)
If it is the same CPU socket type your only small problem may be connecting the front panel wires (led/hdd/reset/usb/audio)
Aug 01, 2010 | MSI K8M NEO-V Motherboard
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
FoxConn 661MO3-G-6EL is suuposed to have 2 1394 Firewire ports installed, 1 in the rear panel and 1 accessible on the board from a front bus connector, but mine seems to be msssing these, whcih does not...
Return the motherboard to the place where you bought it, and have them explain the differences that you have observed.
Are there any wires running from the FireWire port on the front of your computer's case to any connector on your motherboard?
May 30, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
K7S&41GXMG-6L-SIS-741GX socket A motherboard
You should be able to get everything you need HERE
Aug 02, 2008 | SIS741GX-MN Motherboard
Computers & Internet Logo
292 people viewed this question
David Payne
David Payne
