Question about Toshiba Computers & Internet
When i charge my laptop it did not show any sign of charging can you give me an explanation
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
How long to charge I only recieved it today
The initial charge will take the longest. I would give it 4 to 8 hours to fully charge.
Mar 07, 2016 | Audio Players & Recorders
My laptop battery is 3 years old is it time for a new one
only replace the battery if it is showing signs of not fully charging or not holding a charge for a reasonable amount of operations
batteries should only be put on charge when at 10% so that a memory is not developed
most laptops will charge and work while on the charger
Dec 31, 2015 | Computers & Internet
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Dell inspiron 1525 pluged in not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Dec 02, 2012 | Dell Inspiron 1525 Notebook
My laptop not charging
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
My laptop won't charge when plugged in...I changed the charger but still won't charge
Or:
Possible solutions:
Or:
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
