Question about Whirlpool Ovens
Hi. I have a whirlpool oven T : FXTM6. The display just flashes "stop". I have unplugged it but I can't get past "stop". Is there a simple solution here ? Gary
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Hi OldTech, Whirlpool Acubake electric oven
Hi
F2-E0 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 21, 2011
My digital display is not working on my Whirlpool Super Capacity 465
Your problem is most likely the main circuit board for the control panel. That is really the brains for the oven. Ovens are funny things to put electronics in. Electronics do not like heat and what use is an oven that doesn't get hot. I have replaced several of these boards in the recent past and that is what you are most probably going to need to do. Should be an easy replacement. Just be careful removing and replacing the connectors. Some are very fragile (not a good thing to engineer in for a consumer product). I would recommend that you get the model number from the door tag and call one of the appliance replacement companies or Sears for a replacement control board. I would remove the original and make sure that you are ordering the right part number. Manufacturers have a bad habit of switching control boards mid production year, so you could end up with a replacement that will not work.
Aug 02, 2012 | Whirlpool Ovens
Hi OldTech, Whirlpool Acubake electric oven stopped working after it suddenly displayed a flashing F2EO error message accompanied by a persistent beep. I unplugged and plugged it again. Thought it...
Hi
Daniel
Aug 21, 2011 | Ovens
On my whirlpool oven FCEM6 the display says STOP and I can not get anything to work.
hi i have a whirlpool oven type fcem6 model akz151/1x i turned the oven on and it triped the eletric and the oven would not work so i got a new element and now just the grill works but not the oven help plz
Dec 28, 2010 | Ovens
Oven won't light and the display is flashing E1 F1
HI. This is essentially a board code(EEPROM check-sum error). Use this check procedure to confirm failure.
1. Safely disconnect the power from the affected unit for five minutes.(Shut of the appropriate circuit breaker or unplug from the wall)
2. Re-apply power and observe for at least one minute.
3. If the code re-appears, replace the main control board (also called ERC or clock).
Jul 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 | Ovens
Ovens Logo
275 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
