Question about TEKK Fitness Two Treadmill
I have a lifegear Pacemaker Pro Treadmill. after i ahve used it for 5 minutes the machine gives error signal and I have to restart my session
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Lifegear treadmill
You might inquire of Lifegear how many watts it consumes
Jun 04, 2013 | Exercise & Fitness
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
Mar 23, 2013 | Lime Pro Lime Mt9 Treadmill Exercise...
Lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
Feb 22, 2013 | Exercise & Fitness
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Owners manual for lifegear manual treadmill
I have a lifegear treadmill and get an E2 error and the treadmill will not move.
Aug 19, 2010 | Exercise & Fitness
My pacemaker starts throbbing in my abdomin at 17.15 hrs every day which lasts for 3 minutes. is this normal
Boy is this posted in the wrong place. "If the pacemaker has one lead, it is known as a single chamber pacemaker. The lead can be placed in either the right atrium or the right ventricle. This type of device can be used only if the signal from the SA node or the AV node is the problem, and all other electrical conduction in the patient's heart is working correctly. Patients with this type of pacemaker can sometimes feel an uncomfortable neck throbbing, chest fullness or faintness when the device fires, known as pacemaker syndrome. Because of this problem, and the general ability to pump a greater volume of blood, some patients are treated with a dual chamber system."--BNET
http://findarticles.com/p/articles/mi_gGENH/is_20050229/ai_2699003575/
Oct 25, 2009 | Pacemaker Plumbing
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
TEKK Fitness  Two Treadmill Logo
226 people viewed this question
Top TEKK Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a TEKK Exercise and Fitnes Expert? Answer questions, earn points and help others
