Question about 2wire (1000-000057-000) Modem
I got this model 2701HGV-E Gateway router and want to do bridge mode to my currently brought linksys N series router WRT160N and how to i configure to let the linksys router access internet bridge connection through the old router. Any solution for me to fix that?
4 Suggested Answers
  • 31 Answers
SOURCE: connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
Posted on May 20, 2009
  • 10406 Answers
SOURCE: Everytime I restart my computer I have to run the
Cut power to the router.
Reconnect it, and let it start-up, for 2 minutes.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG /ALL and press ENTER.
Record the information, e.g., 'IPCONFIG /ALL > temp.txt'
Type IPCONFIG /RENEW and press ENTER.
Better? Worse? Same?
Posted on Nov 01, 2009
  • 110 Answers
SOURCE: 2701HGV-E Power Broadband & Internet led in
Check for the user name and the password for the connectivity. Internet light red only means either the user name or the password is incorrect. Try entering the password and try again it should help.
Posted on Jun 21, 2010
How can i set up my wrt160N? please help
Here, go to this site and it will give you instructions on how to configure you linksys wrt160n router
http://www.wikihow.com/Configure-a-Linksys-WRT160N-Router
Hope i help. please rate my solution thanks.
Jun 30, 2011 | Linksys WRT160N Wireless Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
2-Wire 3800HGV-B bridge mode
Hello my friend,
You can disable all routing functions for your Home Portal. I never advise this as a course of action as it typically causes more issues than it resolves - so procede at your own risk.
- use the button on the back to reset to factory state (hold for 30 seconds)
- browse to gateway.2wire.net/mdc
- click on configure under broadband link
- set ATM PVC search to disabled
- set connection type to direct IP
- click on configure services under the advanced heading
- take note of the text under "If you want to connect to the gateway when it is in bridged mode"
- un-check the enable routing box
- submit your settings
Good Luck!
Oct 30, 2009 | 2wire HomePortal® 1800HW Router...
My Linksys WRT160n seems to be very weak. My
Try rebooting the router first...unplug then plug it back in.
Then check your settings to make sure it's configured properly. For example, it hasn't changed itself to b or g mode, etc.
You may be getting interference from someone else's router. Try changing the channel...1, 6, and 11 are the best as they are separated from each other. Most routers are by default on channel 6, you may find less interference on channels 1 or 11. The freeware program Network Stumbler can tell you what channel other networks in your area are using.
Jul 30, 2009 | Linksys WRT160N Wireless Router
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
ADSL ISP provides same address for IP and Gateway
Can you manually change the WAN IP on the router?  If so, give it an IP like 123.12.167.5 and set the gateway address to 123.12.167.1.  If it asks for a subnet mask, give it 255.255.255.0.
If she has a Linksys router, you may need to change the operating "MODE" on it.  A lot of Linksys routers have 2 modes of operation---Router mode and Gateway mode.  For her configuration, make sure the Linksys is in Gateway mode.  This will fix the NAT problem.
Cheers!
Mar 26, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
2wire (1000-000057-000) Modem Logo
543 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
