Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
GE top freezer ice maker leak
Great ice cubes. Water leaks from the fill side of the ice maker - creates big chunk of ice in cube bin.
Need diagram and thots for solving the leak. [GE Profile PTS25 refrig]
Thanks
  • 4 more comments
  • Anonymous Aug 08, 2008
    leaks water just below the filler tube replaced water valve same problem
  • fcsf Sep 04, 2008
    Same problem. Ice building up in the back and signs of leak. How do I fix it?
    Thanks
  • Anonymous Mar 17, 2014
    what make the ice maker make ice and drip water and make a big chunk of ice and freeze all the ice cubes
    kenmore elite 569.76582600 make ice cubes leak water to form chunk of ice with ice cubes whats wrong wiyu my ice maker
  • Anonymous Mar 23, 2014
    When the ice maker is on it is leaking water to the bottom of the freezer
  • Anonymous Mar 28, 2014
    freezer is a -1 everything else is frozen does the freezer go through a defrost cycle
I have the same problem -
Posted on Aug 11, 2008
Leaks into cube bin and freezes up
don't understand what you mean,if you're saying water is dripping into the ice maker more than it should you have a bad water valve,
Nov 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Jul 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
881 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
