Question about Whirlpool RBS275PD Electric Single Oven
My self cleaning oven will not unlock
I have an whirlpool and i cant get my self cleaning oven door wont open,Please tell me what to do
  • Geyergirl Aug 05, 2008
    My oven say's F-3 i am baking something and it starts self cleaning and will not open. I have food in there, How do I get it out?
Tried it but didn't work.
Posted on Jul 08, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
I would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
Posted on May 13, 2008
Oven door won't open after cleaning
The oven shut down before self cleaning completed without a model # this is what I can tell you the TOD thermal overload fuse opened cannot be reset if you have no display then the thermal cavity fuse opened buy a set of feeler gauges from the auto store take one go to top of door in the middle between between door and body push to left door should open.
Sep 24, 2014 | Whirlpool Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
I used my auto self clean on my whirlpool electric oven for the first time, now my oven is off, has been for 6 hrs and the door is stuck closed. how do i turn my oven back on?
Hello there and welcome to fixya
oko well to tell you the truth the cleaning cycle is the hardest cycle for the oven due to the extreem heat during the clean cycle.
Any way the way to unlock the door is as follows
unplug the oven for at least 1 hour then after the hour is over plug it back in and then you may hear a beep if so simply press the cancel button and then unlock the oven door as you would normally do now you may even have to wait for 5 min once you plug it back in but normally it works right away
Now if this doesent work than you may have a faulty controle board this is very common because of the extreem heat and some of the board parts cant take the heat whirlpool is still trying to fix this issue this has been a problem for some time ok?
any way i hope this helps please keep me posted on how this is going
Best regards Mike
Sep 22, 2011 | Whirlpool Ovens
Used self clean oven but when the self cleaning finished the oven door will not open. Please help.....
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Feb 06, 2011 | Whirlpool Ovens
Self cleaning oven
Hello, check door switch,contact should be closed when plunger is actuated.check door circuit for open.
Thanks
May 27, 2010 | Whirlpool GBS307PDS Electric Single Oven
The oven door won't open, and there is still food in it. We have a Whirlpool Super Capacity 465 Model, amd need assistance immediately.
Hello. It is possible that the oven accidentally got turned to the self-clean function. Check to see. If it is set to self-clean, the door lock activated. In order to unlock the oven has to be taken off of self-clean and then it has to cool down to room temperature before it will unlock. Joe
Apr 04, 2010 | Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
White westing house stove cant open oven door
try pushing self clean then cancel or stop/clear
Jun 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
307 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
