Noro heater 6 yrs old - heater works only intermittently. It has economy, comfort and low settings. It also have number settings plus the economy setting - in negative numbers. Not sure why it works sometimes and not others.
ginko
  • 19396 Answers
SOURCE: fan speed button on window air conditioner
This is mot my field of expertise, in any case here is the user manual. Hope it can help
Posted on Feb 25, 2008
  • 518 Answers
SOURCE: fan speed on cool setting only works on low
If it's in Energy Saving mode, that may be normal.
Geno
  • 86 Answers
SOURCE: fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Posted on Mar 16, 2008
  • 8 Answers
SOURCE: vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Posted on Dec 12, 2008
  • 1028 Answers
SOURCE: kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Posted on Dec 17, 2008
Why is my Bosch high flow 21e heater started working intermittently only heating water after tap is turned on and off a few times
Check gas pressures first especially on low setting. Ensure gas burner is clean get unit serviced if over 2 years old. Check or replace water flow sensor & clean inlet filter.
Jul 26, 2014 | Bosch & Tankless LP Hot Water Heater
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pentair 400 2 yrs old won't heat spa to 98 degrees F.
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 18, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Temp is set at 68 degrees ,monitor is still running at 84 degrees in the room. what can be wrong.
Do you have the economy plus button light on? When you press the economy plus, the heater will run until it is 12 degrees above what you have it set on before it will cut off. If this is not the case then you may be looking at a circuit board issue.
Nov 06, 2010 | Heating & Cooling
Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Jan 19, 2010 | Heating & Cooling
I have a Sundance Spa (Altmar - bought in 2004). I've never had a problem before. I just changed out the water and noticed that its not heating as anywhere near as quickly as before. I do not see the icon...
we spoke earlier in chat about the problem. You might also be looking at a sensor that plug into the circuit board. The repair costs shouldn't be more than $100.
Sep 21, 2009 | Pool & Spa
My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
Oct 19, 2008 | Desa International GWP20T GLOWARM Wall...
No picture
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Jun 22, 2007 | Toshiba 55H70 55" Rear Projection...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
