Question about Olevia Televison & Video
My fiance threw the remote and hit the left side of the screen . it didnt break the outside of the screen or even leave a mark but about 6 inches from the edge in looks shattered.
    Brigadier General:
  • 3,006 Answers
The screen is broken and the only fix is to replace it. When the remote hit the edge of the screen it bent a little and cracked a few inches from the edge where the screen was starting to fold a bit. But as the screen is overwhelmingly the single most expensive component in the television it's usually cheaper to replace the entire tv, especially when the labour charges of fitting a new screen are added.
Due to economy of scale, when you buy a flat panel tv you're effectively buying the flat panel at a volume discount and getting the casing, power supply, electronics (in fact all the other bits which turn a bare panel into a tv) for free.
Sorry, but your fiance made an expensive error.
Posted on Sep 04, 2010
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 | Firearms
LG 47ls5700 is , my son threw a 22oz bottle of coke and hit the screen right in the middle.now when it is turned on it looks like the screen is cracked right where he hit the screen ,but on inside of tv...
you need a new LCD panel, if it is available it is not economical to repair. you might try someone such as www.shopjimmy.com
to see if they might have one at an affordable price. you will need your complete model & serial # for the proper part# for your unit.
also try www.encompassparts.com
again you will need complete model/serial#
Nov 14, 2014 | Televison & Video
Kids threw remote at screen and left slight mark that does not wipe off. anyone out there no how to repair kid damage?
It will be best to use a drop of Glycerin to wipe out that place. It won't make any harm, even if that scratch is there.
Gopakumar Gopalan Google
May 01, 2014 | Emerson 40" Lc401em2 1080p 60hz Flat Panel...
I have a 50 inch Pioneer Elite PRO and one of children threw the remote, hit the screen and cracked it. It looks like it is cracked inside (beneath the first layer of glass) The outer sheet of glass is...
My understanding is if any air gets in this area where the glasses are it will not work. You better ask a tv repair man to see if it is worth putting the money in to repair. There should be no charge unless you have him do something to it.
Sep 30, 2017 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Where to wire the e brake so i can have video
Use the parking break bypass procedure, and there is no need to even hook up the break wire.
The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Aug 09, 2009 | Jensen's VM9312 Car DVD Player
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Crack front panel LCD 52 inch TV
My fiance threw my remote at my 52 inch Sony Bravia lcd and I am lost on what to do, How much will it cost to replace the lcd and i dont want to pay to much.help me
Aug 04, 2008 | Televison & Video
Televison & Video Logo
134 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
