Question about Garmin nuvi 200W GPS Receiver
Unlock the maps? I updated with 2009 Garmin CD. It says cant' unlock maps
    President:
  • 1,514 Answers
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Posted on Sep 04, 2010
My GPS keeps saying cant unlock maps after i already loaded maps on it
The Garmin Maps require a map unlock code in order for the GPS to be able to open/access it. Since the maps are copyright protected by Garmin you should of recieved the unlock code from Garmin when you purchased the new map update.
Mar 07, 2010 | Garmin GPS
I recently updated nt2010.20 map since then my nuvi 350 freezes while loading maps i tried reset, hard reset, preboot,when i connect it on USB i cant see device on my PC.is there any way to delete map...
NO!. THE MAPS CAN ONLY BE DELETED USING THE USB CABLE. GO TO GARMIN WEBSITE YOU MAY NEED TO DOWNLOAD THE USB DRIVERS. THEN TRY THE UPDATE AGAIN. IF THE MAPS ARE ON A CD YOU WILL ALSO NEED THE UNLOCK CODES AND THE UNIT SERIAL NUMBER.
Jan 22, 2010 | Garmin Nuvi 350 Car GPS Receiver
No loadind of maps after updating
I have a Nextar gps worked fine for awhile now when i turn it on all it says is reloading. i tried to shut it oee an start again and the same thing happens.
May 22, 2009 | Garmin GPS
Can not download map update 2009 from garmin pls help me
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Purchased CD Garmin Map Update 2009 to update map in my Streetpilot c330. Drver will not install. Troubleshoot info says problem between smart card and windows on my PC. I have windows vista. Set uo...
You need to contact Garmin, and find out if this update CD will work with Vista, some do not if they where made before the driver on the cd was designed for Vista, the update cd that I just used would not, thus I did it on an XP pro system. And it worked ok
Jan 13, 2009 | Garmin GPS
Unlock code
First, I'm rather surprised that you have 2009 map updates... it's still 2008.
Secondly, you may need to call GARMIN to talk to their tech support... they can straighten out this problem if you've already paid for the map update.
1 800 800 1020
You should register your unit on GARMIN's website, it will speed the process.
Jun 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
149 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
