Question about Canon PowerShot A460 Digital Camera
I want to be able to show the date/time on selected pictures
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Nov 16, 2012
  • kakima Nov 16, 2012
Need to activate date/time stamp on Finepix AX200.
In playback mode, press DISP/BACK to select a playback display format. This will turn the Information display on, which will show you the date/time the picture was taken.
This camera does not have a Time/Date Stamp that actually stays on the picture like some cameras do. Instead, the Time/Date Stamp is included in the Image File Properties, and can be viewed or modified from any Windows PC.
Apr 14, 2011 | FUJIFILM FinePix AX200 Digital Camera
Please help me, i have a fuji finepix a350 camera and i won my camera to show the date inside the picture, i tryed all the options but it shows the date for 2-3 seconds on the scren and then does not shows...
You can't get date on the pictures, when viewing them on the screen og on the computer. You can print pictures with date printed on them. Press Menu/OK while viewing the picture on the camera. Select DPOF, select With date. You need to do this with every single picture you want date on. It also requires your printer to be DPOF compatible.
Feb 02, 2010 | Fuji FinePix A350 Digital Camera
Cant get date to show on pictures
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Dec 17, 2009 | Canon PowerShot A480 Digital Camera
How can i take the date off pictures
Here is your answer. I found it on page 52 of the manual in case you have yours and want to refer to it. Hope this helps.
Setting Date/Time, Display on/off.
1.Set camera to still image mode.
2.Press the button that looks like a oval with a "M"on the top. It may be called the Menu button. (I tried to find out what button this was but couldn't find that info.)
3.Press the right or left button to select the "date Stamp".
4. Press the up or down button to select the desired setting.
Select OFF and neither the date or time will be added your photos.
Select DATE and just the date will be added to your photos.
Select date & Time and both of those will show up on your photos.
Jul 20, 2009 | Polaroid i735 Digital Camera
Won't print date on picture
Hi there.
You have to set the time and date to show on the picture using the camera's menu before you take the picture.
You cannot add the time and date to a picture after you have taken it except with photo editing software.
Go into the camera's menu and select the setup option, scroll down to imprint (or something like that) and set it to date and time, press OK or save and from now on the date and time will automatically added to your pictures when you take them.
Good luck and thanks for using FixYa!!
May 22, 2009 | Casio QV-R40 Digital Camera
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Canon A540
The date will only show up on the picture under a limited set of circumstances on the Canon PowerShot digital cameras, of which the A540 is one. You've probably found the Date function in the menu, but discovered that it was off, grayed out, and skipped over whenever you tried to reset it.
Date stamp will only work in "Postcard" mode. Press the Function button (labeled "FUNC SET"), then press the down button until you reach the Recording Pixels selection (usually labeled "L", but not always). It's probably the bottom onscreen selection. Use the right or left buttons to select Postcard, then press the Function button again.
Press the Menu button and scroll down to Date Stamp. Now you should be able to select "Date" or "Date & Time" with the right or left button. Press Menu again and take your pictures.
Sep 29, 2008 | Canon PowerShot A540 Digital Camera
Date and timestamps
Is there a way to select a group of pictures on the camera and give them all the same date and/or time stamp?
No
Each JPG will show the date on which it was taken, but not on the photo, it will show it on your computer under the column "date picture taken"
Jan 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Managing the Time and Date
I have found the answer to the date problem. The date is hidden and will not show up unless you insert it during printing. When printing in ACDsee select print image, then click on the CAPTION tab, and de-select the box the says "insert date at lower RH corner" or somthing like that. Once it is de-selected it will stay off untill you select it again. By the way you can look into the camera with Microsoft explorer, or any program to copy or open the picture. In my case it is "drive G". I opened Photoshop and drilled down into the camera through drive G, and was able to open the photo without any special dedicated program.
Sep 13, 2005 | Pentax Optio S4 Digital Camera
Canon PowerShot A460 Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
