How to change drum bearings on an indesit WD12X model.
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
Posted on Jun 23, 2008
barkencoa
  • 3463 Answers
SOURCE: rumbling bearings indesit wd12x
It is a normal right hand thread, what you need to do is to apply heat to it with a blow torch,this wiil expand the metal , and should enable you to unscrew it.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
  • 100 Answers
SOURCE: Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Posted on Feb 01, 2009
SOURCE: indesit wd12x
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
Posted on Mar 17, 2009
  • 353 Answers
SOURCE: i have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Posted on Mar 02, 2010
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
Indesit washing machine wd12x manual
Go to the following site.
WWW.INDESITSERVICE.CO.UK
In the menu on the left, click on---INDESIT USER MANUALS.
Then in the search box, enter your model number, and downloat the instructions.
Dec 06, 2010 | Washing Machines
I have a 2 year old indesit wd12x been fine
Mar 01, 2010 | Washing Machines
How do i change the bearings on my indesit we12s macine
Sorry but you can't.
Your model has a polypropylene outer drum and the bearings cannot be removed without breaking it. The only fix is to either replace the entire drum assembly or just the outer drum which is supplied with bearings ready-fitted. If you do go ahead with the repair it's a good idea to replace the drive belt at the same time unless it's absolutely perfect.
As Indesits are super-low priced machines to start with the repair is rarely economically worthwhile as a machine with worn bearings will usually have many other worn parts as well just waiting to fail. Noisy bearings make a horrible noise but usually continue working for quite a while, so it may be better to grit your teeth and put the likely repair costs into the savings towards a new machine.
Feb 15, 2010 | Washing Machines
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Feb 01, 2009 | Washing Machines
Rumbling bearings indesit wd12x
Thanks.
Jan 11, 2009 | Indesit Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
