Question about LG LRSC26910 Side by Side Refrigerator
The freezer dont work - LG LRSC26910 Side by Side Refrigerator
  • LG Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 05, 2010
FRIDGE FREEZER, HAS ONLY THE FRIDGE PORTION WORKING NORMALLY, SO WHY IS FREEZER BARELY ABOVE -2 DEGREES?
the fridge is working and the freezer is freezing so what is your problem?
what is the problem with freezer at -2 degrees? i dont understand what your problem is? ?????
is -2 not cold enough? too cold? what is your problem?? you dont say. do you know the english language? in my world, a refrig that works , but the freezer gets -2 degrees is not a problem? what is your issue ? you dont say? change the setting for the freezer.
if you want it other than -2 degrees. what is the malfunction?
you read and speak english language right?
Dec 29, 2014 | Refrigerators
Fridge and freezer are cool but not cold.fan in freezer doesnt come on the 15 times i checked. compressor is working and the evap fan is working .drain is clear
Have press in on door swtich. This might stop power to fan. Also some fans dont come on unless a tempstat is cold enough. With the box running take the freezer back panel down and see if you have frost on coil and the whole coil is covered with frost, If you dont you have a seal system problem. and need a tech. I hope this helps
Aug 26, 2011 | Whirlpool Refrigerators
Having wiring problem freezer works but fans dont come on aod defrost timer dont kick in need a wiring diagram the serial number is . 88202021 and model number is . gf2ssd for a nor lake reach in...
I have a generic wiring diagram that I use on all my installs that works very well. It is basically the same for most all commercial walk in freezers. Send me a email address and I'll scan and forward what I have.
Oct 10, 2010 | Nor-Lake Freezers
The bottom dont cool
check for ice on the back of wall in freezer section. check to make sure fan motor in freezer turning, if ice on wall you have a defrost problem. bad defrost control or bimetal which is located in freezer section. Check with a ohms meter. should get ohms areading if closed when cold. Last would be a bad defrost heater but rare. Also make sure air returns not block with ice. If so , could be a stop up defrost drain.
Mar 05, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Hotpoint CTX16CYSJLAD freezer works fine but fridge isn't cooling
normally when the freezer works but the refrig doesnt, it is a sign that you either have a defrost problem or your evaporator fan isnt working or the airway between the ref and freezer is blocked. first I would check to see if the fan is working in the freezer section. If it is working then I would check to see where the air comes into the ref from the freezer and make sure you have airflow into the refig section. Some models have a thermostatically controlled damper, i dont think that is what you have though. If you dont have airflow you need to check the defrost system. your would need to remove the evaporator cover and check for icing or frost over the coils. there is several parts to the defrost system. Timer or control board, defrost limit tstat and the heater. To test these components you would need a volt-ohm meter.
Dec 17, 2009 | Refrigerators
Freezer dont work
check the freon charge, it's probably low.
Aug 14, 2009 | Freezers
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRSC26910 Side by Side Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
