Question about Whirlpool LER3622 Dryer
Runs great but will not turn off. starts to overheat
  • 176 Answers
Check the door swtsh
Posted on Sep 04, 2010
Will run great for about 5min at full throttle then will start to miss on one or two sounds like turn off and fish hr.or so then start up and it will run great again for 5 mins and do it again (help)
Common problem is water pump impeller is bad. Should be checked every spring. When water pump isn't providing enough water to cool motor, thermocouple in motor will stop motor to avoid damage. When motor cools, it will restart and run until it overheats again.
Mar 03, 2018 | Boating
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
Car overheat when first run turn car off and back on and car run cool
You might need to replace fan assembly and/or thermostat. Mine was overheating only when stopped at traffic lights. Only one fan was working and would cause the car to overheat. Working great after fan swap.
Jun 20, 2012 | 2002 Dodge Intrepid
Cooling system
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 14, 2012 | 1996 Toyota Avalon
Overheating
Car runs hot?
overheating?
Feb 12, 2012 | 1997 Dodge Intrepid
I have a 91 V6 4Runner that was overheating. I put a new radiator in since it had a crack in it. Car ran great for 2 days then today overheated once again. no signs of leaks anywhere. Could it be the
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Jan 27, 2012 | 1994 Toyota 4Runner
Runs great for 10 min then stops. Once cool will restart and runs great for another 10 min. Do B&S have a thermal overheat shutdown?
No overheat protective shutdown. You could have vapor locking of your fuel line, could depend on how far away your fuel filter is from the carburetor. or the ignition coil is failing.
I hope this helps.
Jul 22, 2011 | Garden
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
Whirlpool LER3622 Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
