Question about Samsung 510N 15" Flat Panel LCD Monitor
I am using LCD monitor LG, my son changed some settings which i don't know, Presently, the monitor says Out of range 53.6KHZ / 60HZ. What is the problem and How to solve this problem and restoration of my computer
  • Samsung Master
  • 12,061 Answers
OK, at boot time pump the F8 key, when the safe mode menu shows choose Boot in VGA, now when it does so, & when at the desktop, right click on desktop, and select properties, then choose a Lower resolution, say 1024x768, 32 bit or, the common maximum, 1280x1024 32 bit. set and reboot, this time the monitor should boot and the screen should work.
If that doesn't work, then boot up again with VGA, and select a lower mode say 800x600 32 bit.
If it will not boot or display anything, then you most likely have either a fault with the Video card or the monitor, to test try the Monitor on another machine, if it works OK, then your Video Card is faulty. you will have to replace it.
If it proves to be the Monitor, you will have to repair or replace.
Posted on Sep 04, 2010
    President:
  • 2,571 Answers
He may have changed the display settings on the computer. He may have altered the refresh rate higher than the monitor can handle.
You can try start the computer in safe mode (F8 repeatedly on boot up, till the safe mode option comes up)
This will load basic video drivers, you should be able to check your settings now.
Windows xp / right click on desktop and your settings are there
OR control panel / display
What is the problem of HP w1972a LCD monitor ?
If you have problem with your pc graphic card boot in safe mode 640 x 400 and change the settings of graphic card to 1366x768 60 hz. Then boot normal
May 06, 2014 | HP w1907 LCD Monitor
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
I have upto now been using my lg Flatron L1919S monitor as a tv with a separate tuner. Today i replaced it with an lcd tv and was going to use the monitor for my computer. However when i connected it up...
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | LG Flatron L1919S LCD Monitor
Out of range
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | LG Flatron L1750S 17" LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
Signal out of range
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Nov 10, 2008 | Kogi L7CH Monitor
Analog out of range
The TV maxes at a 60Hz refresh rate, and the game refreshes at a 120Hz refresh rate - common problem for that game and this TV - you will have to change the game resoltuion to 480i or 480p from the gaming system/pc itself (or change pc refresh rate to 60Hz, and 480 X whatever reoslution).
May 26, 2008 | Gateway FPD2275W LCD Monitor
Analor out of range
lower refresh rate to 60hz
Oct 28, 2006 | LG L1722P 19" LCD Monitor
Samsung 510N 15" Flat Panel LCD Monitor Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
