Question about Plumbing
Our Caroma kitchen mixer tap is hard to turn off on hot.
4 Suggested Answers
  • 171 Answers
SOURCE: mixer tap on the kitchen sink
Hi gt_elijah.
I'm Harvey the Master Plumber.
You want to know if there any way to tighten a faucet on a kitchen sink?
Yes! All faucets have to be secure, but there are as many diferent methods as there are diferent manufacturers. If you are unfamiliar with the diferent methods then you might not recognize the screw, nut, bolt or fitting when you look at it. Also, for many, a special tool is required. It might be wise to have someone local look at it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 2692 Answers
SOURCE: mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Posted on Feb 04, 2009
  • 74 Answers
SOURCE: Mixer tap in kitchen hard to turn on and off
It is a simple matter of on o-ring being out of align. REmove the valve cartridge fromthe faucet by first shutting off the water at the shut-off valves. Then remove the handle by means of loosining the set-screw on the front side of the handle. Then remove the valve cartridge by unscrewing the packing nut that surrounds the shiny stem that the handle was connected to.
Once that is removed then the cartridge will slide out, probably with a bit of force. Replace the o-rings and any other washers that may be there and coat liberally with plumbing grease before re-installing. This should fix you right up.
Bring the old cartridges, rings and washers with you to your home improvement store to make replacing easier. Should be about $15-$20.
Good luck.
Posted on Apr 28, 2009
I Have a cold water dripping in my sink the taps are mixer taps i have fitted a new washer but it still drips also it is tight to turn on and off. also my Hot water tap is hard to turn on it turns quite...
you need to check the seating in the tap for pitting, the new washer will not seal if the seating is pitted. you could fit some TAP REVIVERS which are available from most plumbers merchants.
Sep 08, 2011 | Home
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Mar 26, 2011 | Microwave Ovens
Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
Hi I am looking to buy a table top dishwasher, I have no room to plumb into pipes, will I be able to connect to a mixer tap???????
a dishwaher needs hot water to work properly a mixer i believe works so you do not get burned by hot water i believe correct me if i am wrong with a normal tap all you need is a special fitting for your portable and they usually are supplied with a new one or are cheap to purchase from a plumbing supply or loewes or home depot.check with where you want to purchase washer and ask if they work with a tap mixer
Dec 14, 2009 | Dishwashers
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Good luck.
Apr 25, 2009 | Grohe Classic Kitchen/Bar Faucet ...
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Plumbing Logo
128 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
