Is it possible that my parents wi-fi router for there computer is somehow disrupting the signal for there new wireless sensored hot water system. If so is there a solution?
  • 107 Answers
I understand these to be 2 different MHZ wavelengths... Please look at the MHZ or band of communication number both are using and reply with that so we can help further
Posted on Sep 05, 2010
Wi fi connection keeps dropping
Try changing the channel on the router.
Make sure there are no obstructions around the router.
Airflow is important as these routers do not have fans for cooling.
If possible move the router closer to the computer.
It is not necessarily a problem with the router. It could be the Network card in the computer.
Mar 22, 2014 | Zyxel Computers & Internet
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Wi-fi distance of beetel 450tc1 adsl2+router
Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the other sideof the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 28, 2012 | NetGear WGR614 Wireless Router
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
How do I find out what my security key is?
First connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router settings.
Go to wi fi or wireless menu then find WEP or WAP security code key it is your password to connect wi fi network.If it is in * or # format then add new code so you can connect it with new code.
then save settings and restart router.
Let me know if you need more assistance.
Thanks.
Nov 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Cannot connect to new wi-fi signals
Try removing all past connections , go to control panel , delete all your old settings and start new.
Apr 11, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
