I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and cannot get fridge temperature to go below 12 degrees on the digital display. Freezer compartment seems fine and cold and holding its set temperature! Can this be fixed without calling someone out?
  • toprobroy Apr 23, 2009
    My Fridge temp won't go below  7 now. After switching on and off, it won't go below 14 now.  Also Deodorisor light is on. I've taken them both out for cleaning, but that won't be the reason there is a problem, will it?
    Welcome Back:
    Visited the website for 2 consecutive days.
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
Posted on Jun 03, 2008
  • 828 Answers
It sounds to me as though your fan motor is failing. You need someone to check and replace the fan motor.
Posted on May 13, 2008
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
Loud sound coming from back of fridge. Pulled out from wall. sound like it's coming from the lower left corner when looking at it from the back. Looks like i'd need to take the lower panel off to inspect...
Hi Rick,
Sounds like the now infamous 'fan icing up' caused by a design fault of the fridge evaporator cover assembly & evaporator heater.Contact Samsung.You may find that these components are covered by by an extended 5yr. guarantee. Good luck.I was 30 days outside.
Cheers,
Ron Swift
Nov 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
We have a Samsung Fridge, Model SRS 598 NSS, side by side fridge and freezer. The fridge started making a loud noise when the door was opened as if the fan was coming to a halt. We had someone come out...
sounds like the motor is bad. if you have a warranty have him change it regardless if he thinks it is bad. the motor should not be noisy. If no warranty then have him check motor very good. also low refrigerant charge as well as it running too long can freeze it up and stop the fan. most refrigerators are designed to be against the wall this can be a factor in a freeze condition. I hope this helps you!
Jun 07, 2009 | Refrigerators
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
hi
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
hope this helps
Apr 23, 2009 | Freezers
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
557 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
