I am making a ethernet cable (cat5) with crimp tool and raw ethernet cable. Can't get this to work! I have in this case aprox 25-30 meters of cable. I am now trying with two different qualities of cable, and none of them are working. The cables was ment for a IP-surveillance camera in a hotel. I had to give up, and send the signals thru homeplugs ( thru the electric system in the building ). Now I have these cables at home and want to use them in my home network, but I cant even get the internet signals from my modem to my computer with them. I am testing them with testing tool (diagnostic) and it shows that all 8 have contact. What is the problem? Many thanks
  • deismac Sep 04, 2010
    It's not cross cables.
    I actually found the solution.
    I was thinking that it doesn't matter what colors in what position. But I learned that there are different resistance in the different colors. And I had to place them in the right order( white/orange, orange, white/green, blue, white/blue, green, white/brown, brown.
    At least, now the internet line is working with 100% speed with same cable that I had no signal with only 30 minutes ago. So I guess this was the problem...?
    Can you confirm this?
    Many Thanks!
  • 5,807 Answers
Your Modem Cable uses a different configuration
( uses Cross Cable ),
unlike the Cable for router ( Straight Cable ).
here is a link where you can get one:
http://www.makeitsimple.com/modules.php?name=Content&pa=showpage&pid=8&page=1
To insure your success , have the Modem original cable
and connect it direct on your computer.
If you can connect and browse on the Internet , there is
no reason your Home made cable wont do.
( Normally speaking )
If you can browse on the Internet direct from the Modem
then it is time to connect the Router ( if you have one )
Modem to cross cable to Router then straight cable to
your computer.
If you can open your computer and it says your
computer IP address ( ipconfig ) is 169.254. X X X. X X X
it means you are not connected to the Internet,
although physically connected.
Posted on Sep 04, 2010
  • 2 more comments
  • Rommel Cana
    Rommel Cana Sep 04, 2010
    you will know you are right , if you can browse on the Internet.
    you should also consider the length cause it affects resistance.
    ( Ohms Law )
  • Rommel Cana
    while you still can browse on the Internet, might as well note down in a safe place
    what IP address your computer is having, and if for instance you have a problem
    in the future these will be your guide.( you do not need to post it )
  • Rommel Cana
    sample image on the page
  • Rommel Cana
    and here are wiring diagrams to aid you in the future:
Can the connector in my ihip armour craft be replaced
If it are special connectors there should be special connector plug pliers for it and mounted like to made by the same way as for example cat5 cable connectors .
There should be a special tool to find IN YOUR COUNTRY . where they sell that brand.
It should exactly be the same for special mini plugs if there are 5 to 6 separate wires in the cable, but if its only a 3 wire cable then its easy to soldering a (mini) jackplug
How to Crimp RJ45 to Cat5e or Cat6 cable
Dec 01, 2016 | iHip Audio Players & Recorders
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
Tips on how to fix rj45 connector problem
Replacing the Patch cord is the easiest thing to do. If it is crimped on to the cable coming out of the wall, you should put a jack on it. To replace the clear mod plug on the end, you need another Rj45 mod plug and a crimp tool. These can be purchased at Home Depot, Graybar, Fry's electronics, Radio Shack etc. The crimp tool can be a little expensive but if you are going to need to do any more in the future, you'll have what you need. If you decide to put a Cat5e or Cat6 jack on it, they too can be purchased at the places mentioned above. You would need a punch tool instead of a crimp tool. Some jacks are tool-less but that is not the norm.
Mar 08, 2014 | 3Com NBX 3102 IP Phone
How to fix the Ethernet plug
The broken ethernet plug on the cable can be cut off and a new one can be crimped onto the cable. You need a special crimping tool and the wires needed to be arranged in a specific order in the connector.
If you do not have the skills and the tool then I recommend you purchase a new cable.
Mar 24, 2012 | Computers & Internet
I dont have a crimping tool what can I use in its place to install the DYNEX CAT5 Plugs, and where exactly do I do the squeezing at to lock the cable on
you can use flat precission screw driver and a plier. just place the 8 wires in the connector to their coresponding pins, crossover or straight through. just punch the copper pins one by one with the precission screw, and finaly the wire lock
Aug 15, 2011 | Dynex 20-Piece CAT5/5e Crimp-on Modular...
I am having problem with my network. I am wondering why the new cabling I made I having problem connecting to my assisting network. I use belden cat5e and did not even exceed 30 meters lenght. pls help..
Ethernet cables can be 100 meters in length. I would imagine you didn't punch the cable correct.
Make sure you have the wires in the correct order if they are not it wont work. Just stick to making straight through cables as most routers, switches and hubs are now smart enough to reverse logic if needed.
Here is wiring of A to A http://networkcable-tester.com/2011/05/23/cat-5-wiring-5/ You can also buy ethernet tester to see which pins are not connected correctly.
If your having trouble making cables I'd suggest just buying some from www.monoprice.com they only cost about $4 for 18' cables
Jul 24, 2011 | Computers & Internet
How to connect RJ45 cat5 cable in wallmount I/O box
how i can punch cat 5 cable in cat 5 io box
Mar 01, 2011 | Leviton (102-5G108-RW5)
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I want to run an ethernet cable under my house. I have cat5e wall plugs, blue ethernet cable, and a Krone tool, but no instructions. Looking on line isn't helping. Can you?
Here's a good instructional video on making ethernet cable:
http://www.youtube.com/watch?v=0S6cjJS5y1I&feature=related
One thing to note: the order of the colors doesn't matter, as long as they match exactly on the other side. Also, make sure you alternate between solid colored wires and wires that are striped.
Stripe/Solid/Stripe/Solid/Stripe/Solid/Stripe/Solid etc.
Jul 24, 2010 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
