Question about Lexmark E260dn Laser Printer
My printer ( Lexmark E260DN ) showing IP Address as 0.0.0.0 & I want to assign IP address so that i will use printer as Network Printer
Instroll this printer in my computer because i have not software this printer
Posted on Sep 09, 2010
Light bulb symbol is lit and the printer won't print. Any ideas how to fix it?
The light bulb light #5 indicates that the printer is ready to print. Therefore the problem lies with the computer side. Typically the problem is that the printer port in Windows does not match the printer port the printer is currently assigned to. If you have the printer connected via ethernet, then your router may have assigned an ip address that is different than when the printer was first set up. You have to go into the printer properties in the control panel, and make sure the port address matches the printer. Once the port is correctly configured, the printer will immediatley start to print.
Oct 15, 2014 | Lexmark E260dn Laser Printer
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
How can I print a configuration page from the E260dn Lexmark?
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
Jul 25, 2012 | Lexmark E260dn Laser Printer
Lexmark Ed260 does not print
OK, if it's timing out that means the printer is not visible to the network. When you used the setup disc, you said it found the same address? What address does it detect? It will mostly likely start with 192.168.x.x. During the setup process does it offer to use DHCP vs a static IP address?
Do you know the IP addresses of the 8 machines on your network? You'll want to make sure the printer doesn't use the same address as that would cause an IP conflict and prevent it from working properly on the network. Preferably you'll want to use an address outside the scope. For example, if your DHCP server is set to give out addresses from 192.168.1.1-.20 then you should make the printer 192.168.1.21. Hope this makes sense.
If that still doesn't get you anywhere, connect the printer directly to a PC via USB and make sure you can print. It's possible it's an issue with the printer, but my guess it's just a network config issue.
Nov 10, 2011 | Lexmark E260dn Laser Printer
Where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it.
1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer.
2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following.
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses.
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
How do I turn on DHCP to my Lexmark e260dn? I can't read it through the network with its current IP address.
1.Turn the printer off.2.Open Front cover.3.Press and hold X button.4.Relese X when the ! LED is illuminated. Note:Be patient as the LEDs will light up in multiple patterns before finaly stopping at !.5.Close front cover. Note:Observe that green button and 3 other LED will be illuminated at the same time.This is Home position.6.Slowly press X button until the 3 first LED are illuminated (paper,toner,light)Note:normaly this will require you to press the X button 11 to 13 times depending on the options and features installed.7. Press and hold green button until all LED flasch or strobe from left to right then relese the button.wait until this process stops with the same pattern as step 6.8.Press and hold X until the light pappern return to the pattern of four LED in theHome position.9.Turn the printer OFF.10.Turn the printer On.Note:if on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP adress to the device.11.Press green button to print a setting pages and observe that all the TCP/IP settings have been reset.12.Reconfigure the device using DHCP.Auto IP(zero configuration) or the IP Setup Utility.
This is my solution to the problem.//Oaklunde
Jul 21, 2011 | Lexmark E260dn Laser Printer
A impressora nao esta ativada, embora esteja conectada ao roteador, como liberar a impressao
When the printer is connected to the network the first time, the router will assign an IP address to it. To get the IP address that the printer was assigned, print a configuration page from the printer. It will show you the IP address on that page somewhere.
Using an Internet browser, type the IP address of the printer into the address line of the browser and press enter. It should bring up a printer configuration window.
Now, since each printer is different, I can't give you the exact steps, HOWEVER, here's what you are looking for:
Find a Network - TCP/IP configuration menu. Somewhere in that menu, it will give you the choice of setting a manual or static IP address versus a DHCP (Dynamic Host Control Protocol) assigned address.
You want to manually set the IP address to the address given on the configuration page. This would normally be 192.168.1.10x where x is any number between 0 and 9. The subnet mask will normally be 255.255.255.0 and the gateway will normally be the IP of the router, usually 192.168.1.1
Once the IP address is assigned permanently to the printer as a static address, you are now ready to add the printer to each computer on your network.
Add the Printer to Your Networked Computers
In Windows XP, follow these steps to add the wireless printer to your computer:
  1. Go to Start, Printers and Faxes.
  2. Double click on Add Printer
  3. Click Next.
  4. On the Local or Network Printer dialog box, choose Local Printer and UNCHECK the box that says "Automatically detect" the printer. Click Next.
  5. On the Select a Printer Port window, choose to Create a New Port, and then under Type of Port, choose Standard TCP/IP port. Click Next.
  6. Make sure the printer is On and Ready, and connected to the network. Click Next.
  7. Type in the static IP address of the printer that you set in the steps above. Click Next.
  8. It will then try to connect to that IP address. It you typed it wrong, or the printer is off, it will come back and give you an error.
  9. If all is well, it should then ask you for the printer driver. If it is an older printer, it may already be listed in Windows. Alternatively, you can insert the CD for the printer, and find the Windows XP English version of the driver. It will be an .inf file most likely.
  10. Double click on the appropriate INF file and then choose the driver you want to install. (the PCL 6 version is usually the one you should choose).
  11. Click Next. It will install the driver and ask you to name the printer.
  12. When it is done, click Finish. (You can choose to print a test page if you want).
Jun 20, 2011 | D-Link AirPlusG DI-524UP Wireless Router
I can't print from my network printer E260
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP addressrange that the router issues to the computers on your network and configure thestatic IP address in the printer's network configuration accordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
You can now print from any computer on your network.
Mar 18, 2011 | Lexmark E260dn Laser Printer
I want connect my lexmark e260dn with ethernet cable, but is not in same network range. How to solve this problem
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
Mar 02, 2011 | Lexmark E260dn Laser Printer
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
Lexmark E260dn Laser Printer Logo
2,357 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
