Question about HP Pavilion a1410n (ER890AA) PC Desktop
Front port of mic is not working? - HP Pavilion a1410n (ER890AA) PC Desktop
  • HP Master
  • 4,924 Answers
If it used to work ..and now it does not .. try to take a look into the settings of the sound driver .. Actually into the sound manager .. it has a map with all in-let and out let used and ..what is assigned for them ...
If you have chosen a 3 out-let scheme for the sound ..(5+1 for example ) .. you have been changed the function of the rear pink in .. , which is a mic in .. and now the front will be also changed into an out -let .. cause teh front are actually just derivations of the back in-lets and out-lets ..
If you do not use an advanced scheme for the audio system ..and do not changed their original functions .. it may be a physical damage .. and you have to take a look on the main board .. on the front audio connectors and see what have been removed from the plug ..
the original map for all the little pins can be found in the manual .. and the manual on the hp support site .
You will need it in case that more than one pin was removed from that connector and you need to place them back ..and do not know which will go in where ...
Good luck and lets hope it is just a driver thing .. By the way if you made changes in the driver and now you can not seam to get it back .. just reinstall it and will be defaulted ..
Posted on Jan 25, 2012
I can't get my microphone to work. I have to use
Look closer at the symbol,it's probably of a earpiece. It's probably a 2.5mm jack port for smaller earpieces.
Mar 18, 2010 | Acer Aspire 5100-5022 Notebook
How can i use headphone's mic on my acer aspire4720z?
there are some ports in the front side of your laptop...try with one headphone with mic....please connect the ports with the cables of the headphone...
Jul 15, 2009 | Computers & Internet
Mic dont work
If you have one front panel and one back panel mic input port, Front panel is active by default on most systems. Try front first. if that is ok..or even if not, click on sound icon near clock (double click) select input/recording. unmute the mic or check it as input. thanks
Apr 03, 2009 | Acer (54.AA806.001) Sound Card
Microphone not working on ps3 w two connections
you should be able to plug each mic into a usb port. (they are the holes on the front of the machine) they each need to be plugged in separately. If this doesn't work there may be a problem with the usb port.
Mar 14, 2009 | Konami Karaoke Revolution: American Idol...
Mic not detecting
The Board have three sound port one for rear one for front and one for mic plug in the mic pin into the mic port red colored.
Then go to the realtek control panel located in the taskbar like a red speaker open it and go to the I/O
options and the mic options turn on front mic.
Jan 31, 2009 | Intel D101GGC Motherboard
Audio
ajayiht22,
If this is the first time you are attempting to use the mic, it must be setup through control panel. Open control panel. Find & open the icon, Sounds and audio decives window will open. Once opened click on the Voice tab. At the bottom of the the window is a button, " Test hardware ". Click it. Follow the instructions from the next few windows. You can not use both front & rear ports at the same time. The ports that work for sound will work for mic once it has been set up.
Jan 13, 2009 | Intel D945GCCR Motherboard
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Mic issues
A8V-VM SE FRONT PANEL AUDIO does not work. The back panel audio speaker port works ok but not the MIC port. I have built over 100 pcs with different motherboards & procesors including several other Asus MoBo both Intel and AMD types. BIOS flas did not help. Asus tech support /knowledge base is useless to find answers.
If anyone has had this problem and solved it , please pot your answer.
Thanks
Oct 22, 2007 | ASUS A8V-VM Motherboard
HP Pavilion a1410n (ER890AA) PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
